[Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Eduardo Gonzalez
eg at gismood.com
Fri Apr 4 10:15:48 PDT 2014
although, as you can see from the name of the file I am running, I am
running a development version I downloaded via OSGeo4W. I thought that the
problem might be the same in your situation anyway.
Eduardo
On Fri, Apr 4, 2014 at 8:13 PM, Eduardo Gonzalez <eg at gismood.com> wrote:
> for me (running Windows 7) it works when I run the qgis-dev.bat file (in
> C:\OSGeo4W\bin) as administrator, if I don run as admistrator I get the
> missing qgis_core.dll error you mention.
> Eduardo
> On Wed, Apr 2, 2014 at 5:08 PM, Matthew Parfitt <
> Matthew.Parfitt at burohappold.com> wrote:
>> Hi Ramon,
>> The program now opens however all of the buttons are greyed out. I will
>> try re-installing whilst logged in as admin and also checking the AV to see
>> if it's blocking anything.
>> Regards,
>> Matthew Parfitt
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org [mailto:
>> qgis-user-bounces at lists.osgeo.org] On Behalf Of Ramon AndiƱach
>> Sent: 02 April 2014 14:54
>> To: qgis-user at lists.osgeo.org List
>> Subject: Re: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
>> don't work
>> Oh, I thought the bat file was in the same directory as the .exe
>> The Desktop and Start Menu icons are just shortcuts to that.
>> -ramon.
>> On 02/04/2014, at 17:52 , Saber Razmjooei wrote:
>> > Hi Matt,
>> > You need to run the .bat file on your desktop or start menu.
>> > Cheers,
>> > Saber
>> > On 2014-04-02 10:49, Matthew Parfitt wrote:
>> >> Hi Saber,
>> >> Yes we do have this .exe. When I run it an error message appears that
>> >> reads:'The program can't start because qgis_core.dll is missing from
>> >> your computer. Try reinstalling the programs to fix this problem.
>> >> We have re-installed a couple of times already.
>> >> Regards,
>> >> Matthew Parfitt
>> >> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saber
>> >> Razmjooei
>> >> Sent: 02 April 2014 10:34
>> >> don't work
>> >> Hi Matt,
>> >> Check if you have the following file to start with:
>> >> C:\Programme Files\QGIS Valmiera\bin\qgis-bin.exe
>> >> Cheers,
>> >> Saber
>> >> On 2014-04-02 10:26, Matthew Parfitt wrote:
>> >>> Hello Saber,
>> >>> Yes we have EndPoint. I'll check the quarantined items and let you
>> >>> know how that goes.
>> >>> Regards,
>> >>> Matthew Parfitt
>> >>> How was my performance? Let my manager know.
>> >>> Please Feedback on our IT Service Performance (only 4 questions!).
>> >>> Razmjooei
>> >>> Sent: 02 April 2014 10:19
>> >>> To: QGIS Users List
>> >>> Hi Matthew,
>> >>> You should be able to have both versions installed. Do you have any
>> >>> AV software installed by any chance? Sometimes it happens that
>> >>> anti-virus software removes *.exe files without making users aware of
>> that.
>> >>> Cheers,
>> >>> Saber
>> >>> ____________________________________________________________________
>> >>> __
>> >>> _________
>> >>> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthew
>> >>> Parfitt
>> >>> Sent: 02 April 2014 09:56
>> >>> Cc: Stephen Henry
>> >>> Subject: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
>> >>> don't work
>> >>> Hello,
>> >>> I have installed QGIS 2.2 Valmiera for my colleague Stephen. He was
>> >>> previously using QGIS 1.8 and still has the version installed.
>> >>> I installed QGIS Standalone installer v2.2 (64Bit). The install went
>> >>> through with no problems but when we tried to open the program via
>> >>> Start>all programs> QGIS Valmiera, nothing happens and the program
>> >>> does
>> >>> not open.
>> >>> Does having 2 versions installed cause problems like this?
>> >>> Thanks in advance.
>> >>> Matthew Parfitt
>> >>> This transmission is confidential and intended solely for the person
>> >>> or organisation to whom it is correctly addressed. If you are not
>> >>> the intended recipient of this transmission, you should not take any
>> >>> action in reliance on it. Further, this transmission may contain
>> >>> confidential design and other information owned by Buro Happold Ltd.
>> >>> You should not copy, distribute, use, offer for sale or hire such
>> >>> information or in any way infringe the design and intellectual
>> >>> property rights of Buro Happold Ltd. It is intended that
>> >>> communication by email from Buro Happold Ltd or its employees is
>> >>> limited to communications connected to the services provided by Buro
>> Happold Ltd.
>> >>> Buro Happold Ltd accepts no liability for any communications not
>> >>> connected to the services it provides.
>> >>> Computer
>> >>> viruses may be transmitted or downloaded onto your computer system
>> >>> via email communication. It is the recipient's responsibility to
>> >>> take any action necessary to prevent computer viruses being
>> >>> transmitted in this way. Accordingly, Buro Happold Ltd disclaims all
>> >>> responsibility which arises directly or indirectly from such
>> >>> transmission of computer viruses. Buro Happold Ltd. Registered in
>> >>> England: 2049511
>> >>> This email and any files transmitted with it are confidential and
>> >>> intended solely for the use of the individual or entity to whom they
>> >>> are addressed.
>> >>> If you have received this email in error please notify the system
>> >>> manager. This message contains confidential information and is
>> >>> intended only for the individual named. If you are not the named
>> >>> addressee you should not disseminate, distribute or copy this e-mail.
>> >>> Please notify the sender immediately by e-mail if you have received
>> >>> this e-mail by mistake and delete this e-mail from your system. If
>> >>> you are not the intended recipient you are notified that disclosing,
>> >>> copying, distributing or taking any action in reliance on the
>> >>> contents of this information is strictly prohibited.
>> >>> Whilst reasonable care has been taken to avoid virus transmission,
>> >>> no responsibility for viruses is taken and it is your responsibility
>> >>> to carry out such checks as you feel appropriate.
>> >>> If this email contains a quote or offer to sell products, carry out
>> >>> work or perform services then our standard terms and conditions
>> >>> (which can be found at
>> >>> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Stan
>> >>> da rd%20Terms%20and%20Conditions.pdf shall apply unless explicitly
>> >>> stated otherwise.
>> >>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>> >>> Qgis-user mailing list
>> >>> Qgis-user at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140404/b96d0425/attachment.html>
