[Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Eduardo Gonzalez eg at gismood.com
Fri Apr 4 10:13:15 PDT 2014
for me (running Windows 7)  it works when I run the qgis-dev.bat file (in
C:\OSGeo4W\bin) as administrator, if I don run as admistrator I get the
missing  qgis_core.dll error you mention.
Eduardo
On Wed, Apr 2, 2014 at 5:08 PM, Matthew Parfitt <
Matthew.Parfitt at burohappold.com> wrote:
> Hi Ramon,
> The program now opens however all of the buttons are greyed out. I will
> try re-installing whilst logged in as admin and also checking the AV to see
> if it's blocking anything.
> Regards,
> Matthew Parfitt
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] On Behalf Of Ramon AndiƱach
> Sent: 02 April 2014 14:54
> To: qgis-user at lists.osgeo.org List
> Subject: Re: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
> don't work
> Oh, I thought the bat file was in the same directory as the .exe
> The Desktop and Start Menu icons are just shortcuts to that.
> -ramon.
> On 02/04/2014, at 17:52 , Saber Razmjooei wrote:
> > Hi Matt,
> > You need to run the .bat file on your desktop or start menu.
> > Cheers,
> > Saber
> > On 2014-04-02 10:49, Matthew Parfitt wrote:
> >> Hi Saber,
> >> Yes we do have this .exe. When I run it an error message appears that
> >> reads:'The program can't start because qgis_core.dll is missing from
> >> your computer. Try reinstalling the programs to fix this problem.
> >> We have re-installed a couple of times already.
> >> Regards,
> >> Matthew Parfitt
> >> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saber
> >> Razmjooei
> >> Sent: 02 April 2014 10:34
> >> don't work
> >> Hi Matt,
> >> Check if you have the following file to start with:
> >> C:\Programme Files\QGIS Valmiera\bin\qgis-bin.exe
> >> Cheers,
> >> Saber
> >> On 2014-04-02 10:26, Matthew Parfitt wrote:
> >>> Hello Saber,
> >>> Yes we have EndPoint. I'll check the quarantined items and let you
> >>> know how that goes.
> >>> Regards,
> >>> Matthew Parfitt
> >>> How was my performance?  Let my manager know.
> >>> Please Feedback on our IT Service Performance (only 4 questions!).
> >>> Razmjooei
> >>> Sent: 02 April 2014 10:19
> >>> To: QGIS Users List
> >>> Hi Matthew,
> >>> You should be able to have both versions installed. Do you have any
> >>> AV software installed by any chance? Sometimes it happens that
> >>> anti-virus software removes *.exe files without making users aware of
> that.
> >>> Cheers,
> >>> Saber
> >>> ____________________________________________________________________
> >>> __
> >>> _________
> >>> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthew
> >>> Parfitt
> >>> Sent: 02 April 2014 09:56
> >>> Cc: Stephen Henry
> >>> Subject: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
> >>> don't work
> >>> Hello,
> >>> I have installed QGIS 2.2 Valmiera for my colleague Stephen. He was
> >>> previously using QGIS 1.8 and still has the version installed.
> >>> I installed QGIS Standalone installer v2.2 (64Bit). The install went
> >>> through with no problems but when we tried to open the program via
> >>> Start>all programs> QGIS Valmiera, nothing happens and the program
> >>> does
> >>> not open.
> >>> Does having 2 versions installed cause problems like this?
> >>> Thanks in advance.
> >>> Matthew Parfitt
> >>> This transmission is confidential and intended solely for the person
> >>> or organisation to whom it is correctly addressed. If you are not
> >>> the intended recipient of this transmission, you should not take any
> >>> action in reliance on it. Further, this transmission may contain
> >>> confidential design and other information owned by Buro Happold Ltd.
> >>> You should not copy, distribute, use, offer for sale or hire such
> >>> information or in any way infringe the design and intellectual
> >>> property rights of Buro Happold Ltd. It is intended that
> >>> communication by email from Buro Happold Ltd or its employees is
> >>> limited to communications connected to the services provided by Buro
> Happold Ltd.
> >>> Buro Happold Ltd accepts no liability for any communications not
> >>> connected to the services it provides.
> >>> Computer
> >>> viruses may be transmitted or downloaded onto your computer system
> >>> via email communication. It is the recipient's responsibility to
> >>> take any action necessary to prevent computer viruses being
> >>> transmitted in this way. Accordingly, Buro Happold Ltd disclaims all
> >>> responsibility which arises directly or indirectly from such
> >>> transmission of computer viruses. Buro Happold Ltd. Registered in
> >>> England: 2049511
> >>> This email and any files transmitted with it are confidential and
> >>> intended solely for the use of the individual or entity to whom they
> >>> are addressed.
> >>> If you have received this email in error please notify the system
> >>> manager. This message contains confidential information and is
> >>> intended only for the individual named. If you are not the named
> >>> addressee you should not disseminate, distribute or copy this e-mail.
> >>> Please notify the sender immediately by e-mail if you have received
> >>> this e-mail by mistake and delete this e-mail from your system. If
> >>> you are not the intended recipient you are notified that disclosing,
> >>> copying, distributing or taking any action in reliance on the
> >>> contents of this information is strictly prohibited.
> >>> Whilst reasonable care has been taken to avoid virus transmission,
> >>> no responsibility for viruses is taken and it is your responsibility
> >>> to carry out such checks as you feel appropriate.
> >>> If this email contains a quote or offer to sell products, carry out
> >>> work or perform services then our standard terms and conditions
> >>> (which can be found at
> >>> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Stan
> >>> da rd%20Terms%20and%20Conditions.pdf shall apply unless explicitly
> >>> stated otherwise.
> >>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140404/06254639/attachment.html>
