[Qgis-user] connection ODBC QGIS/FilemakerPro 10
Gaëlle Audebert gaelle.audebert at numericable.fr
Fri Apr 4 13:43:23 PDT 2014
Hi there,
I try to establish an ODBC connection between a database FilemakerPro 10 and QGIS software but I have some problems with installation. At first , I activated ODBC sharing of my file in my Filemaker database . I work on a 64bits Operating System which requires me to go through the System32 to recover Administrator ODBC data sources. I tried to make the link with DataDirect SequeLink 6.0 but also with ODBC Filemaker, I loaded with win64 driver, the connection test succeeded in both cases. I encounter problems when I pass on QGIS and I make a connection from the addition of a vector or from the evis connection to a database, in the first case the following error message appears: "Connection to [localhost.name of my database] failed: The specified driver was not loaded due to system error 182 (DataDirect SequeLink 6.0, C: \ Windows \ system32 \ DataDirect \ slodbc60 \ ivslk22.dll) QODBC3. Unable to establish a connection. "And in the second case, QGIS stops functioning. Would you have a solution for me?
I just met another problem with QGIS, I georeferenced cadastral maps on ArcGIS and I would like to import them into QGIS so that my colleagues could view them, unfortunately the plans are not displayed georeferenced.
Thank you for your help and excuse me for my English,
Gaëlle
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140404/d83e1bfd/attachment.html>
