[Qgis-user] GRASS functions in the toolbox don't work (missing dependency)
William Kyngesburye woklist at kyngchaos.com
Wed Apr 9 07:14:17 PDT 2014
The default path in QGIS should work, my QGIS package has an internal GRASS.  The path from that thread would only work if you have an external GRASS installed.  Do you have the latest QGIS 2.2?  There was a packaging error in early packages that killed GRASS.
Unfortunately Processing doesn't log errors from testing for the presence of dependencies, so it's hard to figure out why it fails to find a dependency.  Some system level errors will be shown in Console.app: All Messages.
On Apr 9, 2014, at 6:53 AM, Olivier Dalang <olivier.dalang at gmail.com> wrote:
> Hi !
> I'm trying to use v.clean from the toolbox under QGIS 2.2 on Mac OS X, but get the following error :
> Missing dependency.This algorithm cannot be run :-(
> This algorithm requires GRASS to be run. Unfortunately, it seems that GRASS is not installed in your system, or it is not correctly configured to be used from QGIS
> Click here<http://docs.qgis.org/2.0/html/en/docs/user_manual/processing/3rdParty.html> to know more about how to install and configure GRASS to be used with QGIS
> I found this thread : http://lists.osgeo.org/pipermail/qgis-user/2013-November/024870.html
> where someone suggested to set
> "/Applications/QGIS.app/Contents/MacOS/grass/bin:/Applications/QGIS.app/Contents/MacOS/grass/scripts:/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:/usr/bin:/bin:/usr/sbin:/sbin" as environnement variable PATH in QGIS, but is has no effect upon restarting QGIS (still the same error)...
> Does anyone have an idea ? Thanks a lot !!
> Olivier
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
