[Qgis-user] selecting a point that is using point displacement?
Andreas Neumann a.neumann at carto.net
Sun Apr 13 02:09:27 PDT 2014
Hi Ben,
You can select them at their original point location. In the symbology
setting you can display the original point. While editing, you should
enable this symbology setting to display the center point. If you need
to select an individual one, you can do so by using the attribute table
and the associated selection tools.
Andreas
Am 11.04.2014 12:46, schrieb benjamin.donner at kimitoon.fi:
> Hi all, if I have, say, 3 points that are shown using the point displacement tool (i.e., they are not shown exactly where they actually are), how on earth do I select them for editing / moving / deleting? Using the normal Select single feature-tool does not work, probably because I am pressing the symbol and not the (invisible) place where the point actually is.  I am going to need to edit or move around 100 points individually, so I really need to be able to select them.
> Regards Ben
> Qgis-user mailing list
