[Qgis-user] selecting a point that is using point displacement?
Ramon AndiƱach
custard at westnet.com.au
Fri Apr 11 06:28:22 PDT 2014
Would running a rectangle select over the area around the point work?
You might get a few extra things, but you could sort out which is which by looking at the attribute table.
-ramon.
> On 11 Apr 2014, at 20:46, <benjamin.donner at kimitoon.fi> wrote:
> Hi all, if I have, say, 3 points that are shown using the point displacement tool (i.e., they are not shown exactly where they actually are), how on earth do I select them for editing / moving / deleting? Using the normal Select single feature-tool does not work, probably because I am pressing the symbol and not the (invisible) place where the point actually is. I am going to need to edit or move around 100 points individually, so I really need to be able to select them.
> Regards Ben
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140411/e5fac988/attachment.html>
