[Qgis-user] Atlas generation - possibility to display data linked to current atlas feature?
Andreas Neumann
a.neumann at carto.net
Mon Apr 14 04:42:37 PDT 2014
I don't think it is possible to use relations in the print
composer/serial printing.
I would be very interested in having these supported. In fact, Nyall
Dawson will work in the future on a reporting mode (not in 2.4, but
maybe in 2.6). I am very interested in having the value relations and
other relations supported.
Currently you will have to use Postgis Views.
Andreas
Am 14.04.2014 11:13, schrieb Alexandre Neto:
> Don't know if the join strategy will work. I normally create the view
> directly on the postgis DB, and works fine.
> According to Nathan, using atlas features fields might be possible in the
> future, but I don't think it is available now.
> http://nathanw.net/2013/12/02/waiting-for-qgis-22-highlighting-current-atlas-feature/
> Alexandre Neto
> On Mon, Apr 14, 2014 at 11:35 AM, Pietro Rossin <pierigis at gmail.com> wrote:
>> Hello everybody
>> I'm working with atlas generation.
>> I must render areas that are on a postgis db.
>> My postgis feature has only some of the fields that I want to display as
>> Text boxes/labels in my composer output.
>> Other features are in other postgres tables (same schema) without geom
>> column.
>> These tables have a common code field.
>> My question is, is it possible to compose labels inside Qgis joining tables
>> to the atlas feature one, is it possible to use the expression calculator
>> or
>> is it better to make a view in postgres collecting all the fields needed?
>> I know is it possible to make some condition using $atlasfeatureid or
>> $atlasgeometry, is it possible to map the same way a field called "code"
>> from the atlas feature to any other table with the same field?
>> Which way is preferable?
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Atlas-generation-possibility-to-display-data-linked-to-current-atlas-feature-tp5134876.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
