[Qgis-user] Atlas generation - possibility to display data linked to current atlas feature?
Alexandre Neto senhor.neto at gmail.com
Mon Apr 14 04:13:49 PDT 2014
Don't know if the join strategy will work. I normally create the view
directly on the postgis DB, and works fine.
According to Nathan, using atlas features fields might be possible in the
future, but I don't think it is available now.
http://nathanw.net/2013/12/02/waiting-for-qgis-22-highlighting-current-atlas-feature/
Alexandre Neto
On Mon, Apr 14, 2014 at 11:35 AM, Pietro Rossin <pierigis at gmail.com> wrote:
> Hello everybody
> I'm working with atlas generation.
> I must render areas that are on a postgis db.
> My postgis feature has only some of the fields that I want to display as
> Text boxes/labels in my composer output.
> Other features are in other postgres tables (same schema) without geom
> column.
> These tables have a common code field.
> My question is, is it possible to compose labels inside Qgis joining tables
> to the atlas feature one, is it possible to use the expression calculator
> or
> is it better to make a view in postgres collecting all the fields needed?
> I know is it possible to make some condition using $atlasfeatureid or
> $atlasgeometry, is it possible to map the same way a field called "code"
> from the atlas feature to any other table with the same field?
> Which way is preferable?
> http://osgeo-org.1560.x6.nabble.com/Atlas-generation-possibility-to-display-data-linked-to-current-atlas-feature-tp5134876.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140414/f4c1248b/attachment.html>
