[Qgis-user] Intersecting NetCDF file attributes with vector layers
Etienne Tourigny etourigny.dev at gmail.com
Mon Apr 14 10:57:23 PDT 2014
You should use the raster calculator to do any calculations on rasters, or
some of the tools in processing. But your use case seems a bit complicated
- perhaps there is a hydrological plugin or processing algorithm that can
help.
Have you tried loading the file in QGIS?
But be aware that netcdf files with many variables are a bit tricky - each
variable is a subdataset, which is treated as a separate file. See the gdal
netcdf page for more details [1].
You could translate them to individual files in another format like gtiff
using gdal:
gdal_translate -of gtiff -sds in.nc out
[1] http://www.gdal.org/frmt_netcdf.html
On Mon, Apr 14, 2014 at 1:28 PM, Steve Friedman <skfglades at gmail.com> wrote:
> No.  The Netcdf file has 20+ variables. It is a spatially explicit data
> for hydrological metrics in a large wetland.  I want to associate these
> variables with a vegetation map of the same area.  Then I will conduct a
> GLM multinomial statistical analysis to derive probabilities of vegetation
> community based on the spatial distribution of the hydrologic metrics.
> Hope that make the problem clearer.  If not let me know and I'll try to
> make it more explicit.
> Thanks
> Steve
> On Apr 14, 2014 10:58 AM, "Etienne Tourigny" <etourigny.dev at gmail.com>
> wrote:
>> I don't understand what you mean. You have a netcdf file with 1 variable
>> that has 20+ attributes, and you want to copy them to another raster as
>> metadata? What is the format of your raster?
>> On Mon, Apr 14, 2014 at 9:07 AM, Steve Friedman <skfglades at gmail.com>wrote:
>>> Hello
>>> I have a netcdf file with 20+ attributes that I need to link to a raster
>>> layer.
>>> I do not see a method for this.  I am hoping that I have just missed
>>> something obvious.
>>> Can someone point me in the right direction.
>>> Thank you
>>> Steve
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140414/3bf86e1f/attachment.html>
