[Qgis-user] Intersecting NetCDF file attributes with vector layers
Steve Friedman skfglades at gmail.com
Mon Apr 14 19:21:29 PDT 2014
My mistake.  The shape file is the raster vegetation map and the netcdf
file contains the hydrological metrics.
Sorry for the confusion.
Thank you for the help.
Steve
On Apr 14, 2014 4:34 PM, "Etienne Tourigny" <etourigny.dev at gmail.com> wrote:
> On Mon, Apr 14, 2014 at 3:31 PM, Steve Friedman <skfglades at gmail.com>wrote:
>> Yes I know that netcdf files store arrays of data and that each us
>> treated as a subset of the main file.
>> This is  not a case for raster calculator. NIR is it a case requiring a
>> hydrological plugin.
>> In ArcGis, which is no longer available to me, I used a built in tool to
>> overlay the raster vegetation map with the netcdf shape file representing
>> the hydrological metric of interest.
> netcdf shape file? Never heard of such a thing - QGIS and GDAL only
> support netcdf *raster* files.
> cheers
> Etienne
>>  Perhaps extracting each metric to its own file will yield a reasonable
>> method.
>> Thanks
>> On Apr 14, 2014 1:57 PM, "Etienne Tourigny" <etourigny.dev at gmail.com>
>> wrote:
>> > You should use the raster calculator to do any calculations on rasters,
>> or some of the tools in processing. But your use case seems a bit
>> complicated - perhaps there is a hydrological plugin or processing
>> algorithm that can help.
>> > Have you tried loading the file in QGIS?
>> > But be aware that netcdf files with many variables are a bit tricky -
>> each variable is a subdataset, which is treated as a separate file. See the
>> gdal netcdf page for more details [1].
>> > You could translate them to individual files in another format like
>> gtiff using gdal:
>> > gdal_translate -of gtiff -sds in.nc out
>> > [1] http://www.gdal.org/frmt_netcdf.html
>> > On Mon, Apr 14, 2014 at 1:28 PM, Steve Friedman <skfglades at gmail.com>
>> wrote:
>> >> No.  The Netcdf file has 20+ variables. It is a spatially explicit
>> data for hydrological metrics in a large wetland.  I want to associate
>> these variables with a vegetation map of the same area.  Then I will
>> conduct a GLM multinomial statistical analysis to derive probabilities of
>> vegetation community based on the spatial distribution of the hydrologic
>> metrics.
>> >> Hope that make the problem clearer.  If not let me know and I'll try
>> to make it more explicit.
>> >> Thanks
>> >> Steve
>> >> On Apr 14, 2014 10:58 AM, "Etienne Tourigny" <etourigny.dev at gmail.com>
>> wrote:
>> >>> I don't understand what you mean. You have a netcdf file with 1
>> variable that has 20+ attributes, and you want to copy them to another
>> raster as metadata? What is the format of your raster?
>> >>> On Mon, Apr 14, 2014 at 9:07 AM, Steve Friedman <skfglades at gmail.com>
>> wrote:
>> >>>> Hello
>> >>>> I have a netcdf file with 20+ attributes that I need to link to a
>> raster layer.
>> >>>> I do not see a method for this.  I am hoping that I have just missed
>> something obvious.
>> >>>> Can someone point me in the right direction.
>> >>>> Thank you
>> >>>> Steve
>> >>>> _______________________________________________
>> >>>> Qgis-user mailing list
>> >>>> Qgis-user at lists.osgeo.org
>> >>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140414/23440530/attachment.html>
