[Qgis-user] QGIS Processing broken in Master
Filipe Dias filipesdias at gmail.com
Sun Apr 20 09:31:37 PDT 2014
Hi
I tried copying the most recent version of Processing to its respective
folder inside /usr/share/qgis/python/plugins and I still get the metadata
error. Do I have to wait for another compilation or should it work now?
cheers
F.
On Sun, Apr 20, 2014 at 10:33 AM, Victor Olaya <volayaf at gmail.com> wrote:
> My fault, sorry. I restructured the folders in Processing to have a
> clearer structure, but forgot to update the make files. Hope is fixed now.
> sorry again
> Victor
> 2014-04-20 11:06 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> confirmed..
>> trying to compile master the first error I get is:
>> - -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
>> CMake Error at python/plugins/processing/CMakeLists.txt:3
>> (ADD_SUBDIRECTORY):
>>   add_subdirectory given source "admintools" which is not an existing
>>   directory.
>> followed by a lot of messages in this style .. basically all external
>> tools like gdal, grass, grass7, taudem, saga, otb, r, lidar
>> - -- Ctest Binary Directory  set to:
>> /home/macho/dev/cpp/QGIS/build/output/bin
>> - -- Configuring incomplete, errors occurred!
>> CMakeList missconfiguration?
>> regards
>> Werner
>> On 04/20/2014 10:32 AM, Filipe Dias wrote:
>> > Hi
>> > I just did a clean installation of QGIS Master on Ubuntu 12.04
>> > (also deleted ./qgis2) and Processing is broken. In the plugin
>> > manager this message shows up:
>> > *This plugin is broken* Missing metadata file
>> > Installed version: ? (in
>> > /usr/share/qgis/python/plugins/processing) Available version:
>> > 2.2.0-1 (in QGIS Official Plugin Repository)
>> > However, in /usr/share/qgis/python/plugins/processing  there's an
>> > apparently normal metadata.txt file:
>> > [general] name=Processing description=Spatial data processing
>> > framework for QGIS category=Analysis version=2.0
>> > qgisMinimumVersion=2.0
>> > author=Victor Olaya email=volayaf at gmail.com website=www.qgis.org
>> > icon=images/alg.png
>> > class_name=ProcessingPlugin
>> > Does anyone else have problems with Processing?
>> > Cheers F.
>> > _______________________________________________ Qgis-user mailing
>> > list Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.15 (GNU/Linux)
>> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
>> iEYEARECAAYFAlNTjfAACgkQDAH1YiCxBgmLAgCfb9xmT2biZPNxGWmvUo1ZoSqm
>> QXQAnA85hOKBTrkmtrtYZHu+oIzPz5cG
>> =JxWh
>> -----END PGP SIGNATURE-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140420/9b240d35/attachment.html>
