[Qgis-user] QGIS Processing broken in Master
Werner Macho werner.macho at gmail.com
Sun Apr 20 09:33:48 PDT 2014
with the latest changes from Jürgen in 5f0151cee in CMakeFile
everything works again and is compiling fluently ..
thanks everyone!
regards
Werner
On Sun, Apr 20, 2014 at 6:31 PM, Filipe Dias <filipesdias at gmail.com> wrote:
> Hi
> I tried copying the most recent version of Processing to its respective
> folder inside /usr/share/qgis/python/plugins and I still get the metadata
> error. Do I have to wait for another compilation or should it work now?
> cheers
> F.
> On Sun, Apr 20, 2014 at 10:33 AM, Victor Olaya <volayaf at gmail.com> wrote:
>> My fault, sorry. I restructured the folders in Processing to have a
>> clearer structure, but forgot to update the make files. Hope is fixed now.
>> sorry again
>> Victor
>> 2014-04-20 11:06 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> confirmed..
>>> trying to compile master the first error I get is:
>>> - -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
>>> CMake Error at python/plugins/processing/CMakeLists.txt:3
>>> (ADD_SUBDIRECTORY):
>>>   add_subdirectory given source "admintools" which is not an existing
>>>   directory.
>>> followed by a lot of messages in this style .. basically all external
>>> tools like gdal, grass, grass7, taudem, saga, otb, r, lidar
>>> - -- Ctest Binary Directory  set to:
>>> /home/macho/dev/cpp/QGIS/build/output/bin
>>> - -- Configuring incomplete, errors occurred!
>>> CMakeList missconfiguration?
>>> regards
>>> Werner
>>> On 04/20/2014 10:32 AM, Filipe Dias wrote:
>>> > Hi
>>> > I just did a clean installation of QGIS Master on Ubuntu 12.04
>>> > (also deleted ./qgis2) and Processing is broken. In the plugin
>>> > manager this message shows up:
>>> > *This plugin is broken* Missing metadata file
>>> > Installed version: ? (in
>>> > /usr/share/qgis/python/plugins/processing) Available version:
>>> > 2.2.0-1 (in QGIS Official Plugin Repository)
>>> > However, in /usr/share/qgis/python/plugins/processing  there's an
>>> > apparently normal metadata.txt file:
>>> > [general] name=Processing description=Spatial data processing
>>> > framework for QGIS category=Analysis version=2.0
>>> > qgisMinimumVersion=2.0
>>> > author=Victor Olaya email=volayaf at gmail.com website=www.qgis.org
>>> > icon=images/alg.png
>>> > class_name=ProcessingPlugin
>>> > Does anyone else have problems with Processing?
>>> > Cheers F.
>>> > _______________________________________________ Qgis-user mailing
>>> > list Qgis-user at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.15 (GNU/Linux)
>>> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
>>> iEYEARECAAYFAlNTjfAACgkQDAH1YiCxBgmLAgCfb9xmT2biZPNxGWmvUo1ZoSqm
>>> QXQAnA85hOKBTrkmtrtYZHu+oIzPz5cG
>>> =JxWh
>>> -----END PGP SIGNATURE-----
