[Qgis-user] QGIS Processing broken in Master
Filipe Dias filipesdias at gmail.com
Wed Apr 23 03:49:01 PDT 2014
I downloaded today's QGIS Master and Processing is still unavailable due to
the metadata bug. Anyone else confirms?
regards
F.
On Sun, Apr 20, 2014 at 5:33 PM, Werner Macho <werner.macho at gmail.com>wrote:
> with the latest changes from Jürgen in 5f0151cee in CMakeFile
> everything works again and is compiling fluently ..
> thanks everyone!
> regards
> Werner
> On Sun, Apr 20, 2014 at 6:31 PM, Filipe Dias <filipesdias at gmail.com>
> wrote:
> > Hi
> > I tried copying the most recent version of Processing to its respective
> > folder inside /usr/share/qgis/python/plugins and I still get the metadata
> > error. Do I have to wait for another compilation or should it work now?
> > cheers
> > F.
> > On Sun, Apr 20, 2014 at 10:33 AM, Victor Olaya <volayaf at gmail.com>
> wrote:
> >> My fault, sorry. I restructured the folders in Processing to have a
> >> clearer structure, but forgot to update the make files. Hope is fixed
> now.
> >> sorry again
> >> Victor
> >> 2014-04-20 11:06 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> >>> -----BEGIN PGP SIGNED MESSAGE-----
> >>> Hash: SHA1
> >>> confirmed..
> >>> trying to compile master the first error I get is:
> >>> - -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
> >>> CMake Error at python/plugins/processing/CMakeLists.txt:3
> >>> (ADD_SUBDIRECTORY):
> >>>   add_subdirectory given source "admintools" which is not an existing
> >>>   directory.
> >>> followed by a lot of messages in this style .. basically all external
> >>> tools like gdal, grass, grass7, taudem, saga, otb, r, lidar
> >>> - -- Ctest Binary Directory  set to:
> >>> /home/macho/dev/cpp/QGIS/build/output/bin
> >>> - -- Configuring incomplete, errors occurred!
> >>> CMakeList missconfiguration?
> >>> regards
> >>> Werner
> >>> On 04/20/2014 10:32 AM, Filipe Dias wrote:
> >>> > Hi
> >>> > I just did a clean installation of QGIS Master on Ubuntu 12.04
> >>> > (also deleted ./qgis2) and Processing is broken. In the plugin
> >>> > manager this message shows up:
> >>> > *This plugin is broken* Missing metadata file
> >>> > Installed version: ? (in
> >>> > /usr/share/qgis/python/plugins/processing) Available version:
> >>> > 2.2.0-1 (in QGIS Official Plugin Repository)
> >>> > However, in /usr/share/qgis/python/plugins/processing  there's an
> >>> > apparently normal metadata.txt file:
> >>> > [general] name=Processing description=Spatial data processing
> >>> > framework for QGIS category=Analysis version=2.0
> >>> > qgisMinimumVersion=2.0
> >>> > author=Victor Olaya email=volayaf at gmail.com website=www.qgis.org
> >>> > icon=images/alg.png
> >>> > class_name=ProcessingPlugin
> >>> > Does anyone else have problems with Processing?
> >>> > Cheers F.
> >>> > _______________________________________________ Qgis-user mailing
> >>> > list Qgis-user at lists.osgeo.org
> >>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>> -----BEGIN PGP SIGNATURE-----
> >>> Version: GnuPG v1.4.15 (GNU/Linux)
> >>> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> >>> iEYEARECAAYFAlNTjfAACgkQDAH1YiCxBgmLAgCfb9xmT2biZPNxGWmvUo1ZoSqm
> >>> QXQAnA85hOKBTrkmtrtYZHu+oIzPz5cG
> >>> =JxWh
> >>> -----END PGP SIGNATURE-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140423/bbdf4bdf/attachment.html>
