[Qgis-user] QGIS Processing broken in Master
Goyo goyodiaz at gmail.com
Wed Apr 23 09:08:54 PDT 2014
FWIW version 2.3.0+git20140423+6fa26cf~trusty1 is working here.
2014-04-23 12:49 GMT+02:00 Filipe Dias <filipesdias at gmail.com>:
> Hi,
> I downloaded today's QGIS Master and Processing is still unavailable due to
> the metadata bug. Anyone else confirms?
> regards
> F.
> On Sun, Apr 20, 2014 at 5:33 PM, Werner Macho <werner.macho at gmail.com>
> wrote:
>> with the latest changes from Jürgen in 5f0151cee in CMakeFile
>> everything works again and is compiling fluently ..
>> thanks everyone!
>> regards
>> Werner
>> On Sun, Apr 20, 2014 at 6:31 PM, Filipe Dias <filipesdias at gmail.com>
>> wrote:
>> > Hi
>> > I tried copying the most recent version of Processing to its respective
>> > folder inside /usr/share/qgis/python/plugins and I still get the
>> > metadata
>> > error. Do I have to wait for another compilation or should it work now?
>> > cheers
>> > F.
>> > On Sun, Apr 20, 2014 at 10:33 AM, Victor Olaya <volayaf at gmail.com>
>> > wrote:
>> >> My fault, sorry. I restructured the folders in Processing to have a
>> >> clearer structure, but forgot to update the make files. Hope is fixed
>> >> now.
>> >> sorry again
>> >> Victor
>> >> 2014-04-20 11:06 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
>> >>> -----BEGIN PGP SIGNED MESSAGE-----
>> >>> Hash: SHA1
>> >>> confirmed..
>> >>> trying to compile master the first error I get is:
>> >>> - -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
>> >>> CMake Error at python/plugins/processing/CMakeLists.txt:3
>> >>> (ADD_SUBDIRECTORY):
>> >>>   add_subdirectory given source "admintools" which is not an existing
>> >>>   directory.
>> >>> followed by a lot of messages in this style .. basically all external
>> >>> tools like gdal, grass, grass7, taudem, saga, otb, r, lidar
>> >>> - -- Ctest Binary Directory  set to:
>> >>> /home/macho/dev/cpp/QGIS/build/output/bin
>> >>> - -- Configuring incomplete, errors occurred!
>> >>> CMakeList missconfiguration?
>> >>> regards
>> >>> Werner
>> >>> On 04/20/2014 10:32 AM, Filipe Dias wrote:
>> >>> > Hi
>> >>> > I just did a clean installation of QGIS Master on Ubuntu 12.04
>> >>> > (also deleted ./qgis2) and Processing is broken. In the plugin
>> >>> > manager this message shows up:
>> >>> > *This plugin is broken* Missing metadata file
>> >>> > Installed version: ? (in
>> >>> > /usr/share/qgis/python/plugins/processing) Available version:
>> >>> > 2.2.0-1 (in QGIS Official Plugin Repository)
>> >>> > However, in /usr/share/qgis/python/plugins/processing  there's an
>> >>> > apparently normal metadata.txt file:
>> >>> > [general] name=Processing description=Spatial data processing
>> >>> > framework for QGIS category=Analysis version=2.0
>> >>> > qgisMinimumVersion=2.0
>> >>> > author=Victor Olaya email=volayaf at gmail.com website=www.qgis.org
>> >>> > icon=images/alg.png
>> >>> > class_name=ProcessingPlugin
>> >>> > Does anyone else have problems with Processing?
>> >>> > Cheers F.
>> >>> > _______________________________________________ Qgis-user mailing
>> >>> > list Qgis-user at lists.osgeo.org
>> >>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> >>> -----BEGIN PGP SIGNATURE-----
>> >>> Version: GnuPG v1.4.15 (GNU/Linux)
>> >>> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
>> >>> iEYEARECAAYFAlNTjfAACgkQDAH1YiCxBgmLAgCfb9xmT2biZPNxGWmvUo1ZoSqm
>> >>> QXQAnA85hOKBTrkmtrtYZHu+oIzPz5cG
>> >>> =JxWh
>> >>> -----END PGP SIGNATURE-----
> Qgis-user mailing list
