[Qgis-user] argument 1 has unexpected type error when parse xml with ElementTree
Suryo Miles suryomiles666 at gmail.com
Tue Apr 22 22:26:01 PDT 2014
I try to make plugin in QGIS Dufour to open and read xml metadata and then
to show some information in metadata i try to parse it with ElementTree and
then show it in QLineEdit, this code i use to open metadata and parse
metadata :
from PyQt4 import QtCore, QtGui
from ui_testparse import Ui_testparse
import xml.etree.ElementTree as ETree
# create the dialog for zoom to point
class testparseDialog(QtGui.QDialog):
    def __init__(self):
        QtGui.QDialog.__init__(self)
        # Set up the user interface from Designer.
        self.ui = Ui_testparse()
        self.ui.setupUi(self)
        opendata = self.ui.btnCari
        QtCore.QObject.connect(opendata,
QtCore.SIGNAL('clicked()'),self.openxml)
    def openxml(self, event=None):
        #open dialog
        openfile = QtGui.QFileDialog.getOpenFileName(self, 'Open File', '*.xml')
        self.ui.lineLokasi.setText(openfile)
        #call XML data
        self.isiData(openfile)
    def isiData(self, nmsatu):
        #open teks with read mode
        openteks = open(nmsatu, 'r').read()
        self.ui.textXml.setText(openteks)
        #Parse XML from Above
        self.parsenow(openteks)
    def parsenow(self, parse):
        element = ETree.fromstring(parse)
        xml_obj = ETree.ElementTree(element)
        for title_obj in
xml_obj.findall('.//{http://www.isotc211.org/2005/gmd}dateStamp/'
             '{http://www.isotc211.org/2005/gco}Date'):
            print element
        self.ui.lineSkala.setText(element)
however when i try to run it, it give me a error message, the error message say:
  File "C:\Users\Mr.Pakde/.qgis2/python/plugins\testparse\testparsedialog.py",
line 47, in openxml
line 56, in isiData
line 64, in parsenow
TypeError: QLineEdit.setText(QString): argument 1 has unexpected type 'Element'
Python version:
2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
and xml file i want to parse look like this :
<gmd:dateStamp>
      <gco:Date>2013-12-12</gco:Date>
Can someone help me, Thanks in Advance
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140423/c0421c0b/attachment.html>
