[Qgis-user] Qgis-user Digest, Vol 98, Issue 40
coen at vuurtooren.nl coen at vuurtooren.nl
Tue Apr 22 23:25:55 PDT 2014
ik heb je update van vannacht opgehaald! Je bent geen ochtend mens...
Hartelijke groet
Coen van Tooren
www.vuurtooren.nl
06-16820375
 Van: qgis-user-request at lists.osgeo.org
Verzonden: dinsdag 22 april 2014 20:48
Aan: qgis-user at lists.osgeo.org
Onderwerp: Qgis-user Digest, Vol 98, Issue 40
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. Re: edit joined fields (Vincent Picavet)
2. Layer Offset (mflue)
3. Re: edit joined fields (R?mi Bovard)
4. Copy/Paste features to existing or new layer (Derek Watling)
5. How to get rid of the rest of the World? (kmgkmgkmgkmg .)
6. Re: How to get rid of the rest of the World? (Simon Cropper)
7. Re: How to get rid of the rest of the World? (Alexandre Neto)
8. Re: How to get rid of the rest of the World? (Alex Mandel)
9. Re: Trusty 14.04 install from QGIS.org (Zoltan Szecsei)
10. Re: [Qgis-developer] Trusty 14.04 install from QGIS.org
(J?rgen E. Fischer)
11. Newbie: New Shapefile Layer Won't Save (eric at greatriverair.com)
Message: 1
Date: Tue, 22 Apr 2014 13:44:45 +0200
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] edit joined fields
Message-ID: <201404221344.45186.vincent.ml at oslandia.com>
Content-Type: Text/Plain;  charset="iso-8859-1"
Hello,
Le mardi 22 avril 2014 10:10:13, R?mi Bovard a ?crit :
> Hi Stefan,
> Just a note, wouldn't it be better to have one table being given the 1-1
> relationship?
> In any case, with PostGIS you can create a view, add rules on it
(update,
> insert, delete) and the load this editable view in QGIS. Something like:
> ON UPDATE TO <view> DO INSTEAD UPDATE <table> SET <attribute>=
> new.<attribute>
Rules on PostgreSQL are an old system and not recommended.
It is advised to use triggers instead for this kind of use case.
Note that latest PostgreSQL versions have automatic writeable views (for
simple views), no need to do anything to activate it.
http://www.postgresql.org/docs/9.3/static/sql-createview.html
Vincent
> HTH
> R?mi
> 2014-04-22 9:47 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > > my problem is that both of my layers are stored in a Postgis
> > > database and it does not help me if I have to create a new layer
> > > which would then not refer to the original tables anymore. Of
> > > course, a workaround could be a new layer inside the database that
> > > would then update the original tables with a trigger function. But
> > > I was wondering if there is an easier way to go in QGIS.
> > if your layers are stored in a PostGIS database I should give up.. For
> > now I'm not a PostGIS guru.. :(
> > good luck!
> > Matteo
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.12 (GNU/Linux)
> > Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> > iQEcBAEBAgAGBQJTVh6fAAoJEBy7UYf0gaEOdNwH/imIlzH9qnUAbxxZOTPy/wka
> > 6gawQvw21iLMlmOFD2g7PwhqjEvzW+fRkRTVzvGQnOIoJfM6bPirAf6zrTmY3znU
> > 2lyJsEwdFSkABGHOfgelv6KwF/T2uBJqBJ6ourCIrGx2KWYTYR3EYV401+gaw6eh
> > aHLBREQ7GyMbc7ERNqAVKuyuZ98Ya/TfT3lRBVJA9oWIGGkoEW7MS5/+Q4ge92sK
> > 03hK+Hp+7wv5CVW7K8zbCQeaHcXc52sChU1YmW3Yl2Hu9vxyTuRA161gDbXEStXs
> > qFxVH98ItTYk7Y2jiaTulJMp61Ktk8G7WN4RT8bgEsjpfB9h+kc4LhUMiaOrxFI=
> > =dPqA
> > -----END PGP SIGNATURE-----
> > Qgis-user at lists.osgeo.org
Message: 2
Date: Tue, 22 Apr 2014 06:13:15 -0700 (PDT)
Subject: [Qgis-user] Layer Offset
Message-ID: <1398172395627-5136446.post at n6.nabble.com>
Content-Type: text/plain; charset=UTF-8
I have a problem alining one layer in my project.
So far I added a google map using the open layer plugin as well as a
delimited Text file with geocoded adresses.
The CRS is set to WGS 84 - EPSG:4326 for the adresses and WGS 84 / Pseudo
Mercator - EPSG: 3857 for the google map. Both layers alligne very nicely.
My problem lies in the layer of zip codes which I imported from the
shapefile in this link http://arnulf.us/PLZ.
According to the description theshapefile is coded in WGS84 - EPSG:4326.
I set the CRS to this value again and enabled OTF-Projection so I guess I
made everything correct so far.
Anyway I get an north-east offset of approx. 300 meter. There is a hint on
that website regarding this offset in german but I cannot figure out how
to
set this offset.
"Je nach Koordinatensystem k?nnen die Daten gleichm??ig bis zu mehrere
hundert Meter nach Nordosten verschoben sein. Man kann das Problem aber
beheben, indem man einen Versatz in der Projektion ber?cksichtigt."
I appreciate any help and explanation why this happens and how to solve
the
issue.
THX mflue
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Layer-Offset-tp5136446.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Message: 3
Date: Tue, 22 Apr 2014 15:16:01 +0200
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Message-ID:
<CANkSeKPM86hojo8CWQzFmb=b=+95k5PRcS8+pDUcpzhwH4j11Q at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Thanks for your input Vincent, I wasn't aware about that.
R?mi
2014-04-22 13:44 GMT+02:00 Vincent Picavet <vincent.ml at oslandia.com>:
> Hello,
> > Hi Stefan,
1-1
> > relationship?
(update,
like:
> > new.<attribute>
> Vincent
> > HTH
> > R?mi
> > > Hash: SHA1
For
> > > good luck!
> > > Matteo
> > > =dPqA
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20140422/52f27c47/at
tachment-0001.html>
Message: 4
Date: Tue, 22 Apr 2014 06:39:12 -0700 (PDT)
Subject: [Qgis-user] Copy/Paste features to existing or new layer
Message-ID: <1398173952039-5136455.post at n6.nabble.com>
Content-Type: text/plain; charset="us-ascii"
I am new to QGIS, having used Manifold for the past several years. I have
exported some test data to a PostGIS database and created a test map with
some sample layers. I am running QGIS 2.2.0 x64 on Windows 7.
*What I've done:* I select some features and go Edit > Cut/Copy
Features...
If I select *Edit > Paste Features as > New [Memory] Vector Layer* I get
the
error message *Cannot create field TextCol (varchar,QString)*
If I paste onto an existing layer only attribute data from columns with
matching names is copied and if there is a type mis-match the edit can't
be
commited.
*Question:* What is the best way to copy/cut features and paste them onto
a
new/existing layer layer?
http://osgeo-org.1560.x6.nabble.com/Copy-Paste-features-to-existing-or-new-l
ayer-tp5136455.html
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20140422/c0d1665f/at
tachment-0001.html>
Message: 5
Date: Tue, 22 Apr 2014 14:57:32 +0100
Subject: [Qgis-user] How to get rid of the rest of the World?
Message-ID:
<CAAuUpbaej+=+GuDzfXWi3S1qHnbf3Criw=tv4W-41JaDPhvXRw at mail.gmail.com>
Hello everyone..
I will be going on a little bit here now..
Wonder how to create a clip/mask layer or do something to the same effect?
More specifically, how to make a rectangular area of longitude and
latitude
coordinates that enables to cut away the area not needed in other layers?
Since stuck with a quarter of the World or even the entire World in my
little project. This question is for shape file layers mostly, have not
gotten to the .tiff yet. They are not global though larger then needed. So
a universal solution for both types would be nice.
Is there a python console command to do this?
Is there a plugin to do this?
Is there a online service to create such a layer?
Is it possible from within QGIS?
Have tried the make a rectangle plugin, it cuts out zero features.
Also tried clipping with a layer of not the right shape and it says that
they do not have the right projection, even though it looks as they do,
and
end up with a blank layer.
Sure plenty people have this problem, though the forums do not have any
clear explanations as I found nothing that really explains, even youtube
got one but that is for regional borders.
Is there some way of just knocking in the longitude and latitude to do
this?
Please assist. Do not get why this should be so difficult.
Why does not QGIS ask first thing which area of the planet you wish to
work
on a project? And then just filter out it automatically when you load
layer
that include more than that? Perhaps this could be a feature of a future
release?
With hopes for many answers and simple solutions. I repeat just want a
specified area that easily can be determined by longitude and latitude
coordinates.
Yours hopefully..
Marcus
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20140422/576f9f42/at
tachment-0001.html>
Message: 6
Date: Wed, 23 Apr 2014 00:24:29 +1000
From: Simon Cropper <simoncropper at fossworkflowguides.com>
Subject: Re: [Qgis-user] How to get rid of the rest of the World?
Message-ID: <53567B9D.9020707 at fossworkflowguides.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Marcus,
I think what you are asking is can you just view the area that you are
working on and have QGIS hide or filter out those feature not within the
area of concern.
>From my understanding is no. Well not exactly.
My understanding is that shapefiles will allways be processed regardless
of whether they are visable. Feature may not be visible if they are
outside the view or transparent.
You have two simple solutions to this problem.
1. Create a routine to, or manually, clip all the shapefiles in your
project based on a reference polygon bounded by your lat/longs.
2. Create a polygon covering the world and punch a hole through it,
essentially creating a window bounded by your lat/longs. The polygon can
be made opaque/white making it the same as the screen/page or
semi-transparent, essentially fading the underlying features (nice
effect in reports).
On 22/04/14 23:57, kmgkmgkmgkmg . wrote:
> Hello everyone..
effect?
> latitude coordinates that enables to cut away the area not needed in
> other layers?
> So a universal solution for both types would be nice.
> and end up with a blank layer.
this?
> work on a project? And then just filter out it automatically when you
> load layer that include more than that? Perhaps this could be a feature
> of a future release?
> coordinates.
> Yours hopefully..
> Marcus
Cheers Simon
Simon Cropper - Open Content Creator
Free and Open Source Software Workflow Guides
Introduction               http://www.fossworkflowguides.com
GIS Packages           http://www.fossworkflowguides.com/gis
bash / Python    http://www.fossworkflowguides.com/scripting
Message: 7
Date: Tue, 22 Apr 2014 16:33:44 +0100
To: "kmgkmgkmgkmg ." <km.gulver at gmail.com>
Cc: QGIS User <qgis-user at lists.osgeo.org>
Message-ID:
<CA+H0G_HYCBpNpQ7KwK9B0eOAX0qKuThoRmgn_SVJzKcbkQs12g at mail.gmail.com>
Hello Marcus,
The feature I believe you are describing is being worked by a few
developer, have a look in this pull request:
https://github.com/qgis/QGIS/pull/1254
Maybe it lands in QGIS 2.4 :)
Alexandre Neto
On Tue, Apr 22, 2014 at 2:57 PM, kmgkmgkmgkmg . <km.gulver at gmail.com>
wrote:
> Hello everyone..
effect?
other
> layers?
So
and
> this?
load
> layer that include more than that? Perhaps this could be a feature of a
> future release?
> coordinates.
> Yours hopefully..
> Marcus
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20140422/b8e46e47/at
tachment-0001.html>
Message: 8
Date: Tue, 22 Apr 2014 08:49:33 -0700
To: Simon Cropper <simoncropper at fossworkflowguides.com>,
Message-ID: <53568F8D.8060703 at wildintellect.com>
I usually make a new vector Layer. Then you can draw or use the
numerical vector editor to add a polygon. This polygon can then be used
as a clipping mask. Simply having a layer of a given extent isn't
enough, you have to have a polygon object in the layer.
As for why this isn't the way it already is, well QGIS is not ArcINFO or
GRASS where all data in one map are forced into the same projection and
you can set an extent property for the analysis. That's a different
concept of how to do GIS. One that is not very forgiving to projection
on the fly.
Thanks,
Alex
On 04/22/2014 07:24 AM, Simon Cropper wrote:
> Marcus,
> area of concern.
> effect in reports).
>> Hello everyone..
>> effect?
>> other layers?
that
youtube
>> this?
>> coordinates.
>> Yours hopefully..
>> Marcus
Message: 9
Date: Tue, 22 Apr 2014 19:23:06 +0200
To: qgis-user at lists.osgeo.org, 	"qgis-developer at lists.osgeo.org"
<qgis-developer at lists.osgeo.org>
Subject: Re: [Qgis-user] Trusty 14.04 install from QGIS.org
Message-ID: <5356A57A.9090307 at geograph.co.za>
Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
Hi DevList,
I've moved this over from 'user' to 'dev'.
Is there an upcoming fix to get python-qgis working with the
sip-api-11.0 that comes with Ubuntu 14.04 64 bit?
Thanks,
Zoltan
On 2014/04/22 00:58, Randal Hale wrote:
> Just for fun I upgraded a test install of ubuntu 12.04 to 14.04.
> Master Debian-nightly installs nicely.
> Stable release for trusty complains:
> /rjhale at gis2:/etc/apt/sources.list.d$ sudo apt-get install qgis
> python-qgis//
> //Reading package lists... Done//
> //Building dependency tree //
> //Reading state information... Done//
> //Some packages could not be installed. This may mean that you have//
> //requested an impossible situation or if you are using the unstable//
> //distribution that some required packages have not yet been created//
> //or been moved out of Incoming.//
> //The following information may help to resolve the situation://
> //The following packages have unmet dependencies://
> // python-qgis : Depends: python-qgis-common (= 2.2.0-1+trusty1) but
> it is not going to be installed//
> //               Depends: sip-api-10.1 but it is not installable//
> // qgis : Depends: libqgis2.2.0 but it is not going to be installed//
> //        Depends: libspatialite3 (>= 2.4.0~rc2) but it is not
> installable//
> //        Depends: qgis-providers (= 2.2.0-1+trusty1) but it is not
> //        Recommends: qgis-plugin-grass but it is not going to be
> installed//
> //        Recommends: qgis-plugin-globe but it is not going to be
> installed//
> //E: Unable to correct problems, you have held broken packages./
> Just an FYI -
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611rjhale at northrivergeographic.com
> twitter:rjhale
> http://about.me/rjhale
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax:    +27-86-6115323     www.geograph.co.za
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20140422/0ad0eee6/at
tachment-0001.html>
Message: 10
Date: Tue, 22 Apr 2014 19:54:53 +0200
To: qgis-developer at lists.osgeo.org, qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] [Qgis-developer] Trusty 14.04 install from
QGIS.org
Message-ID: <20140422175453.GA7703 at norbit.de>
Content-Type: text/plain; charset=iso-8859-1
Hi Zoltan,
On Tue, 22. Apr 2014 at 19:23:06 +0200, Zoltan Szecsei wrote:
> Hi DevList,
The note about the stable debian packages for not yet release
distributions
also applies to ubuntu.  The packages were made before trusty was released
and
trusty meanwhile changed[1].
The packages just needed a rebuild.   Try again now.
J?rgen
[1] http://qgis.org/en/site/forusers/alldownloads.html#debian
J?rgen E. Fischer         norBIT GmbH               Tel.
+49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstra?e 13            Fax.
+49-4931-918175-50
Software Engineer         D-26506 Norden
http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Message: 11
Date: Tue, 22 Apr 2014 14:39:57 -0400 (EDT)
Subject: [Qgis-user] Newbie: New Shapefile Layer Won't Save
Message-ID: <1398191997.471224032 at webmail.greatriverair.com>
I'm pretty sure this is basic, but I'm stymied.
QGis 2.2.0
Running on Windows 7 Pro
Plugins: A M  Flightplanner, OpenLayers, GRASS
Attempting: Layer ->New->New Shapefile Layer; Select Polygon,
When I try to Save the New Shapefile Layer I get the following error mssg:
Creation of OGR data source C:/Program Files (x86)/QGIS
Valmiera/bin/example.shp failed: Failed to open Shapefile 'C:/Program Files
(x86)/QGIS Valmiera/bin\example.shp'
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20140422/ac90606c/at
tachment.html>
End of Qgis-user Digest, Vol 98, Issue 40
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140423/fc2f55fb/attachment.html>
