[Qgis-user] Hachure construction
venerio giuseppe anardu anardu.geol at yahoo.it
Wed Apr 23 06:09:56 PDT 2014
I don't think this task can be accomplished automatically, but if it could be possible it will be awesome!
Anyway, I've found this article:
http://mike.teczno.com/notes/hachures.html
Greetings
Il Mercoledì 23 Aprile 2014 14:43, Frank Broniewski <brfr at metrico.lu> ha scritto:
Hey,
thank you for your answer. I will definitely try that out, Although I am
not yet convinced that automatic hachure generation is doable in QGIS.
I've seen more possibilites for doing this in a Autocad extension/
plugin (Quvadis).
Frank
Am 2014-04-21 02:58, schrieb maning sambale:
> Another approach would be from a DEM, generate slope and aspect.  Add
> the values to a point vector layer and follow Imhof's rules.
> I made a similar experiment many moons ago.  Check the last two photos
> in this post:
> http://epsg4253.wordpress.com/2012/05/14/alternatives-to-relief-shading/
> "The arrows depicts the direction of the surface (aspect) while the
> line thickness depicts the steepness of the gradient (slope)."
> On Fri, Apr 18, 2014 at 3:36 PM, Frank Broniewski <brfr at metrico.lu> wrote:
>> Hi,
>> I'd like to construct manually some hachures in order to show the
>> terrain form, like in ye olde maps
>> (http://en.wikipedia.org/wiki/Hachure_map)
>> I am working with contours that I have available. Using the snapping
>> options I can already draw lines between two contour lines just fine,
>> but a hachure line is usually drawn in the direction of the steepest
>> slope. So it would be useful to have a length indicator, just like with
>> the measurement tool, when digitizing lines. Because the shortest
>> distance between two points would represent the steepest slope and that
>> is what I want to know.
>> So how can I get the current line length while digitizing? Is there some
>> plugin? I am also not afraid of using Python to achieve this, but I've
>> never done any QGIS modding so far ...
>> Many thanks,
>> Frank
>> Frank BRONIEWSKI
>> METRICO s.à r.l.
>> géomètres
>> technologies d'information géographique
>> rue des Romains 36
>> L-5433 NIEDERDONVEN
>> tél.: +352 26 74 94 - 28
>> fax.: +352 26 74 94 99
>> http://www.metrico.lu
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
rue des Romains 36
L-5433 NIEDERDONVEN
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140423/8ffe1b14/attachment.html>
