[Qgis-user] Displaying the command of Database Shapefile Loader
Gunnar Oehmichen
oehm8895 at uni-landau.de
Fri Apr 18 07:26:45 PDT 2014
Hello There,
Using QGIS 2.2 on Ubuntu 12.04.
I uploaded a shapefile to a remote postgis-database using the
DatabaseManger -> Import Shapefile.
Is it possible to display the shp2pgsql command qgis used to load a
shapefile to a postgisdatabase (I guess QGIS is just using the tool). I
would like to compare this command to what Ive entered manually into the
terminal, producing the following error (Probably not belonging here):
I tried to do a shp2pgsql command:
shp2pgsql -i shapefile.shp schema.test | psql -h localhost -d 'DB' -U
oehmichen
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
Password for user USER:
SET
SET
BEGIN
NOTICE: CREATE TABLE will create implicit sequence "test_gid_seq" for
serial column "test.gid"
CREATE TABLE
NOTICE: ALTER TABLE / ADD PRIMARY KEY will create implicit index
"test_pkey" for table "test"
ALTER TABLE
addgeometrycolumn
planee.test.geom SRID:0 TYPE:MULTIPOLYGON DIMS:2
(1 row)
ERROR: invalid input syntax for type numeric: "7313000,000000000000000"
LINE 1: ...56Z','Basis-DLM','urn:adv:oid:9110','301IRDC_006','7313000,0...
Thanks for your help,
Gunnar
