[Qgis-user] QGIS Processing broken in Master
Filipe Dias
filipesdias at gmail.com
Wed Apr 23 10:32:09 PDT 2014
Well, this is weird:
I run "sudo qgis" and now Processing shows up and I don't get the metadata
error
Any ideas on why this happened?
On Wed, Apr 23, 2014 at 6:19 PM, Filipe Dias <filipesdias at gmail.com> wrote:
> I just did clean installation of QGIS Master from ubuntugis nightly and it
> still get this message. Am I missing something?
> *This plugin is broken*
> Missing metadata file
> On Wed, Apr 23, 2014 at 6:01 PM, Filipe Dias <filipesdias at gmail.com>wrote:
>> Ok
>> I'm on Ubuntu 12.04
>> On Wed, Apr 23, 2014 at 5:08 PM, Goyo <goyodiaz at gmail.com> wrote:
>>> FWIW version 2.3.0+git20140423+6fa26cf~trusty1 is working here.
>>> 2014-04-23 12:49 GMT+02:00 Filipe Dias <filipesdias at gmail.com>:
>>> > Hi,
>>> > I downloaded today's QGIS Master and Processing is still unavailable
>>> due to
>>> > the metadata bug. Anyone else confirms?
>>> > regards
>>> > F.
>>> > On Sun, Apr 20, 2014 at 5:33 PM, Werner Macho <werner.macho at gmail.com>
>>> > wrote:
>>> >> with the latest changes from Jürgen in 5f0151cee in CMakeFile
>>> >> everything works again and is compiling fluently ..
>>> >> thanks everyone!
>>> >> regards
>>> >> Werner
>>> >> On Sun, Apr 20, 2014 at 6:31 PM, Filipe Dias <filipesdias at gmail.com>
>>> >> wrote:
>>> >> > Hi
>>> >> > I tried copying the most recent version of Processing to its
>>> respective
>>> >> > folder inside /usr/share/qgis/python/plugins and I still get the
>>> >> > metadata
>>> >> > error. Do I have to wait for another compilation or should it work
>>> now?
>>> >> > cheers
>>> >> > F.
>>> >> > On Sun, Apr 20, 2014 at 10:33 AM, Victor Olaya <volayaf at gmail.com>
>>> >> > wrote:
>>> >> >> My fault, sorry. I restructured the folders in Processing to have a
>>> >> >> clearer structure, but forgot to update the make files. Hope is
>>> fixed
>>> >> >> now.
>>> >> >> sorry again
>>> >> >> Victor
>>> >> >> 2014-04-20 11:06 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
>>> >> >>> -----BEGIN PGP SIGNED MESSAGE-----
>>> >> >>> Hash: SHA1
>>> >> >>> confirmed..
>>> >> >>> trying to compile master the first error I get is:
>>> >> >>> - -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
>>> >> >>> CMake Error at python/plugins/processing/CMakeLists.txt:3
>>> >> >>> (ADD_SUBDIRECTORY):
>>> >> >>> add_subdirectory given source "admintools" which is not an
>>> existing
>>> >> >>> directory.
>>> >> >>> followed by a lot of messages in this style .. basically all
>>> external
>>> >> >>> tools like gdal, grass, grass7, taudem, saga, otb, r, lidar
>>> >> >>> - -- Ctest Binary Directory set to:
>>> >> >>> /home/macho/dev/cpp/QGIS/build/output/bin
>>> >> >>> - -- Configuring incomplete, errors occurred!
>>> >> >>> CMakeList missconfiguration?
>>> >> >>> regards
>>> >> >>> Werner
>>> >> >>> On 04/20/2014 10:32 AM, Filipe Dias wrote:
>>> >> >>> > Hi
>>> >> >>> > I just did a clean installation of QGIS Master on Ubuntu 12.04
>>> >> >>> > (also deleted ./qgis2) and Processing is broken. In the plugin
>>> >> >>> > manager this message shows up:
>>> >> >>> > *This plugin is broken* Missing metadata file
>>> >> >>> > Installed version: ? (in
>>> >> >>> > /usr/share/qgis/python/plugins/processing) Available version:
>>> >> >>> > 2.2.0-1 (in QGIS Official Plugin Repository)
>>> >> >>> > However, in /usr/share/qgis/python/plugins/processing there's
>>> an
>>> >> >>> > apparently normal metadata.txt file:
>>> >> >>> > [general] name=Processing description=Spatial data processing
>>> >> >>> > framework for QGIS category=Analysis version=2.0
>>> >> >>> > qgisMinimumVersion=2.0
>>> >> >>> > author=Victor Olaya email=volayaf at gmail.com website=
>>> www.qgis.org
>>> >> >>> > icon=images/alg.png
>>> >> >>> > class_name=ProcessingPlugin
>>> >> >>> > Does anyone else have problems with Processing?
>>> >> >>> > Cheers F.
>>> >> >>> > _______________________________________________ Qgis-user
>>> mailing
>>> >> >>> > list Qgis-user at lists.osgeo.org
>>> >> >>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> >> >>> -----BEGIN PGP SIGNATURE-----
>>> >> >>> Version: GnuPG v1.4.15 (GNU/Linux)
>>> >> >>> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
>>> >> >>> iEYEARECAAYFAlNTjfAACgkQDAH1YiCxBgmLAgCfb9xmT2biZPNxGWmvUo1ZoSqm
>>> >> >>> QXQAnA85hOKBTrkmtrtYZHu+oIzPz5cG
>>> >> >>> =JxWh
>>> >> >>> -----END PGP SIGNATURE-----
>>> > Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140423/e8563ea0/attachment.html>
