[Qgis-user] QGIS Processing broken in Master
Etienne Tourigny
etourigny.dev at gmail.com
Wed Apr 23 11:35:26 PDT 2014
probably the persistent yet spurius bug with ubuntu that creates a
$HOME/.qgis2 folder as root after install...
On Wed, Apr 23, 2014 at 2:32 PM, Filipe Dias <filipesdias at gmail.com> wrote:
> Well, this is weird:
> I run "sudo qgis" and now Processing shows up and I don't get the metadata
> error
> Any ideas on why this happened?
> On Wed, Apr 23, 2014 at 6:19 PM, Filipe Dias <filipesdias at gmail.com>wrote:
>> I just did clean installation of QGIS Master from ubuntugis nightly and
>> it still get this message. Am I missing something?
>> *This plugin is broken*
>> Missing metadata file
>> On Wed, Apr 23, 2014 at 6:01 PM, Filipe Dias <filipesdias at gmail.com>wrote:
>>> Ok
>>> I'm on Ubuntu 12.04
>>> On Wed, Apr 23, 2014 at 5:08 PM, Goyo <goyodiaz at gmail.com> wrote:
>>>> FWIW version 2.3.0+git20140423+6fa26cf~trusty1 is working here.
>>>> 2014-04-23 12:49 GMT+02:00 Filipe Dias <filipesdias at gmail.com>:
>>>> > Hi,
>>>> > I downloaded today's QGIS Master and Processing is still unavailable
>>>> due to
>>>> > the metadata bug. Anyone else confirms?
>>>> > regards
>>>> > F.
>>>> > On Sun, Apr 20, 2014 at 5:33 PM, Werner Macho <werner.macho at gmail.com
>>>> > wrote:
>>>> >> with the latest changes from Jürgen in 5f0151cee in CMakeFile
>>>> >> everything works again and is compiling fluently ..
>>>> >> thanks everyone!
>>>> >> regards
>>>> >> Werner
>>>> >> On Sun, Apr 20, 2014 at 6:31 PM, Filipe Dias <filipesdias at gmail.com>
>>>> >> wrote:
>>>> >> > Hi
>>>> >> > I tried copying the most recent version of Processing to its
>>>> respective
>>>> >> > folder inside /usr/share/qgis/python/plugins and I still get the
>>>> >> > metadata
>>>> >> > error. Do I have to wait for another compilation or should it work
>>>> now?
>>>> >> > cheers
>>>> >> > F.
>>>> >> > On Sun, Apr 20, 2014 at 10:33 AM, Victor Olaya <volayaf at gmail.com>
>>>> >> > wrote:
>>>> >> >> My fault, sorry. I restructured the folders in Processing to have
>>>> a
>>>> >> >> clearer structure, but forgot to update the make files. Hope is
>>>> fixed
>>>> >> >> now.
>>>> >> >> sorry again
>>>> >> >> Victor
>>>> >> >> 2014-04-20 11:06 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
>>>> >> >>> -----BEGIN PGP SIGNED MESSAGE-----
>>>> >> >>> Hash: SHA1
>>>> >> >>> confirmed..
>>>> >> >>> trying to compile master the first error I get is:
>>>> >> >>> - -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
>>>> >> >>> CMake Error at python/plugins/processing/CMakeLists.txt:3
>>>> >> >>> (ADD_SUBDIRECTORY):
>>>> >> >>> add_subdirectory given source "admintools" which is not an
>>>> existing
>>>> >> >>> directory.
>>>> >> >>> followed by a lot of messages in this style .. basically all
>>>> external
>>>> >> >>> tools like gdal, grass, grass7, taudem, saga, otb, r, lidar
>>>> >> >>> - -- Ctest Binary Directory set to:
>>>> >> >>> /home/macho/dev/cpp/QGIS/build/output/bin
>>>> >> >>> - -- Configuring incomplete, errors occurred!
>>>> >> >>> CMakeList missconfiguration?
>>>> >> >>> regards
>>>> >> >>> Werner
>>>> >> >>> On 04/20/2014 10:32 AM, Filipe Dias wrote:
>>>> >> >>> > Hi
>>>> >> >>> > I just did a clean installation of QGIS Master on Ubuntu 12.04
>>>> >> >>> > (also deleted ./qgis2) and Processing is broken. In the plugin
>>>> >> >>> > manager this message shows up:
>>>> >> >>> > *This plugin is broken* Missing metadata file
>>>> >> >>> > Installed version: ? (in
>>>> >> >>> > /usr/share/qgis/python/plugins/processing) Available version:
>>>> >> >>> > 2.2.0-1 (in QGIS Official Plugin Repository)
>>>> >> >>> > However, in /usr/share/qgis/python/plugins/processing there's
>>>> an
>>>> >> >>> > apparently normal metadata.txt file:
>>>> >> >>> > [general] name=Processing description=Spatial data processing
>>>> >> >>> > framework for QGIS category=Analysis version=2.0
>>>> >> >>> > qgisMinimumVersion=2.0
>>>> >> >>> > author=Victor Olaya email=volayaf at gmail.com website=
>>>> www.qgis.org
>>>> >> >>> > icon=images/alg.png
>>>> >> >>> > class_name=ProcessingPlugin
>>>> >> >>> > Does anyone else have problems with Processing?
>>>> >> >>> > Cheers F.
>>>> >> >>> > _______________________________________________ Qgis-user
>>>> mailing
>>>> >> >>> > list Qgis-user at lists.osgeo.org
>>>> >> >>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> >> >>> -----BEGIN PGP SIGNATURE-----
>>>> >> >>> Version: GnuPG v1.4.15 (GNU/Linux)
>>>> >> >>> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
>>>> >> >>> iEYEARECAAYFAlNTjfAACgkQDAH1YiCxBgmLAgCfb9xmT2biZPNxGWmvUo1ZoSqm
>>>> >> >>> QXQAnA85hOKBTrkmtrtYZHu+oIzPz5cG
>>>> >> >>> =JxWh
>>>> >> >>> -----END PGP SIGNATURE-----
>>>> > Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140423/3120c315/attachment.html>
