[Qgis-user] QGIS Processing broken in Master
Filipe Dias filipesdias at gmail.com
Wed Apr 23 13:33:38 PDT 2014
Hi, thanks for the tips
Actually it was not the ever present ~/.qgis2 permissions bug.
I went to /usr/share/qgis and changed the permissions on that folder to my
user name. I have no idea how this happened but I write here solution in
case anyone else comes across this.
Regards
On Wed, Apr 23, 2014 at 7:35 PM, Etienne Tourigny
<etourigny.dev at gmail.com>wrote:
> probably the persistent yet spurius bug with ubuntu that creates a
> $HOME/.qgis2 folder as root after install...
> On Wed, Apr 23, 2014 at 2:32 PM, Filipe Dias <filipesdias at gmail.com>wrote:
>> Well, this is weird:
>> I run "sudo qgis" and now Processing shows up and I don't get the
>> metadata error
>> Any ideas on why this happened?
>> On Wed, Apr 23, 2014 at 6:19 PM, Filipe Dias <filipesdias at gmail.com>wrote:
>>> I just did clean installation of QGIS Master from ubuntugis nightly and
>>> it still get this message. Am I missing something?
>>> *This plugin is broken*
>>> Missing metadata file
>>> On Wed, Apr 23, 2014 at 6:01 PM, Filipe Dias <filipesdias at gmail.com>wrote:
>>>> Ok
>>>> I'm on Ubuntu 12.04
>>>> On Wed, Apr 23, 2014 at 5:08 PM, Goyo <goyodiaz at gmail.com> wrote:
>>>>> FWIW version 2.3.0+git20140423+6fa26cf~trusty1 is working here.
>>>>> 2014-04-23 12:49 GMT+02:00 Filipe Dias <filipesdias at gmail.com>:
>>>>> > Hi,
>>>>> > I downloaded today's QGIS Master and Processing is still unavailable
>>>>> due to
>>>>> > the metadata bug. Anyone else confirms?
>>>>> > regards
>>>>> > F.
>>>>> > On Sun, Apr 20, 2014 at 5:33 PM, Werner Macho <
>>>>> werner.macho at gmail.com>
>>>>> > wrote:
>>>>> >> with the latest changes from Jürgen in 5f0151cee in CMakeFile
>>>>> >> everything works again and is compiling fluently ..
>>>>> >> thanks everyone!
>>>>> >> regards
>>>>> >> Werner
>>>>> >> On Sun, Apr 20, 2014 at 6:31 PM, Filipe Dias <filipesdias at gmail.com
>>>>> >> wrote:
>>>>> >> > Hi
>>>>> >> > I tried copying the most recent version of Processing to its
>>>>> respective
>>>>> >> > folder inside /usr/share/qgis/python/plugins and I still get the
>>>>> >> > metadata
>>>>> >> > error. Do I have to wait for another compilation or should it
>>>>> work now?
>>>>> >> > cheers
>>>>> >> > F.
>>>>> >> > On Sun, Apr 20, 2014 at 10:33 AM, Victor Olaya <volayaf at gmail.com
>>>>> >> > wrote:
>>>>> >> >> My fault, sorry. I restructured the folders in Processing to
>>>>> have a
>>>>> >> >> clearer structure, but forgot to update the make files. Hope is
>>>>> fixed
>>>>> >> >> now.
>>>>> >> >> sorry again
>>>>> >> >> Victor
>>>>> >> >> 2014-04-20 11:06 GMT+02:00 Werner Macho <werner.macho at gmail.com
>>>>> >> >>> -----BEGIN PGP SIGNED MESSAGE-----
>>>>> >> >>> Hash: SHA1
>>>>> >> >>> confirmed..
>>>>> >> >>> trying to compile master the first error I get is:
>>>>> >> >>> - -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
>>>>> >> >>> CMake Error at python/plugins/processing/CMakeLists.txt:3
>>>>> >> >>> (ADD_SUBDIRECTORY):
>>>>> >> >>>   add_subdirectory given source "admintools" which is not an
>>>>> existing
>>>>> >> >>>   directory.
>>>>> >> >>> followed by a lot of messages in this style .. basically all
>>>>> external
>>>>> >> >>> tools like gdal, grass, grass7, taudem, saga, otb, r, lidar
>>>>> >> >>> - -- Ctest Binary Directory  set to:
>>>>> >> >>> /home/macho/dev/cpp/QGIS/build/output/bin
>>>>> >> >>> - -- Configuring incomplete, errors occurred!
>>>>> >> >>> CMakeList missconfiguration?
>>>>> >> >>> regards
>>>>> >> >>> Werner
>>>>> >> >>> On 04/20/2014 10:32 AM, Filipe Dias wrote:
>>>>> >> >>> > Hi
>>>>> >> >>> > I just did a clean installation of QGIS Master on Ubuntu 12.04
>>>>> >> >>> > (also deleted ./qgis2) and Processing is broken. In the plugin
>>>>> >> >>> > manager this message shows up:
>>>>> >> >>> > *This plugin is broken* Missing metadata file
>>>>> >> >>> > Installed version: ? (in
>>>>> >> >>> > /usr/share/qgis/python/plugins/processing) Available version:
>>>>> >> >>> > 2.2.0-1 (in QGIS Official Plugin Repository)
>>>>> >> >>> > However, in /usr/share/qgis/python/plugins/processing
>>>>>  there's an
>>>>> >> >>> > apparently normal metadata.txt file:
>>>>> >> >>> > [general] name=Processing description=Spatial data processing
>>>>> >> >>> > framework for QGIS category=Analysis version=2.0
>>>>> >> >>> > qgisMinimumVersion=2.0
>>>>> >> >>> > author=Victor Olaya email=volayaf at gmail.com website=
>>>>> www.qgis.org
>>>>> >> >>> > icon=images/alg.png
>>>>> >> >>> > class_name=ProcessingPlugin
>>>>> >> >>> > Does anyone else have problems with Processing?
>>>>> >> >>> > Cheers F.
>>>>> >> >>> > _______________________________________________ Qgis-user
>>>>> mailing
>>>>> >> >>> > list Qgis-user at lists.osgeo.org
>>>>> >> >>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> >> >>> -----BEGIN PGP SIGNATURE-----
>>>>> >> >>> Version: GnuPG v1.4.15 (GNU/Linux)
>>>>> >> >>> Comment: Using GnuPG with Thunderbird -
>>>>> http://www.enigmail.net/
>>>>> >> >>> iEYEARECAAYFAlNTjfAACgkQDAH1YiCxBgmLAgCfb9xmT2biZPNxGWmvUo1ZoSqm
>>>>> >> >>> QXQAnA85hOKBTrkmtrtYZHu+oIzPz5cG
>>>>> >> >>> =JxWh
>>>>> >> >>> -----END PGP SIGNATURE-----
>>>>> > Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140423/37a3c0a2/attachment.html>
