[Qgis-user] Can Geoserver use the legends of a QGIS project like qgis server
Andreas Neumann a.neumann at carto.net
Fri Apr 25 01:41:10 PDT 2014
Hi Carlos,
QGIS Server is also mature already. I don't think performance of
Geoserver is much better than QGIS server in real-world scenarios.
At some point you would need multiple servers and load balancing no
matter what mapserver you use.
I would rather try with QGIS server first and see if it is up to the
job. If it isn't one can either improve QGIS server or change to Geoserver.
I don't think legends and print templates from QGIS can be re-used in
Geoserver. There is the SLD-bridge, but it is not perfect and limited.
I understand that Boundless is working on integration of QGIS and
Geoserver - not really sure how well this works already.
If I were you, I would give QGIS server a chance and try it first. It is
important for the development of QGIS that we get feedback from larger
rollouts.
One thing I would avoid is cascading OWS (WMS/WFS) services. It is
better to re-use
There are several provinces/cities using QGIS server in Switzerland,
including our own city administration. There is always room for
improvements, but all in all it is very satisfying, stable and
performance in general good. One room for improvement I can see is a
more persistant and shared layer/project cache, which would speed up
project loading time. Currently, each FCGI instance has it's own cache.
Andreas
Am 25.04.2014 07:53, schrieb Carlos da Ponte:
> I'm trying to decide the best set of applications to use.
> Right now I use QGIS Desktop/QGIS Server/QWC because i like how easy it is
> to take QGIS projects right to the web.  However I'm worried about whether
> QGIS Server can handle the load of an enterprise style rollout (100 users)
> and if I should consider using geoserver instead.  So would the following
> work
> QGIS Desktop - Geoserver - QWC
> Can Geoserver use QGIS projects the same way as QGIS Server?
> Will legends created in QGIS Desktop be maintained in QWC if Geoserver is
> used?
> Are printing templates from Desktop still usuable?
> thanks again!
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-Geoserver-use-the-legends-of-a-QGIS-project-like-qgis-server-tp5137088.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
