[Qgis-user] Can Geoserver use the legends of a QGIS project like qgis server
Victor Olaya volayaf at gmail.com
Fri Apr 25 02:08:51 PDT 2014
> I understand that Boundless is working on integration of QGIS and
> Geoserver - not really sure how well this works already.
You can use the OpenGeo Suite plugin to upload a layer or a whole QGIS
project to a GeoServer instance. It will try to reuse the symbology of the
layer, converting it to SLD (this is done using the core  QGIS
capabilities) and adapting it (this is done by the plugin, since it the SLD
that GeoServer understands is not exactly what QGIS produces). It should
work for the most usual symbologies, but if your layer uses something more
complex, It is not likely that it will work completely.
Hope this helps
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140425/e247ec5a/attachment.html>
