[Qgis-user] 'NULL' labels
Olivier Dalang olivier.dalang at gmail.com
Fri Apr 25 05:41:54 PDT 2014
Are you sure the change is worth it ?
It's true that it's more consistent, but still, 99% of the time, the user
doesn't want to see "NULL" all over the map.
The coalesce expression isn't easy to find out for beginners neither.
For me it's a -1 unless we have an easy way to hide null values (maybe a
checkbox somewhere in the labeling settings to toggle display of null
values, but this is a bit a duplicate of the data defined "show label", or
maybe having coalesce as the expression by default, but this feels a bit
wrong too).
Also I'm not sure it's correct to display the NULL string on the map, as
it's an user-defined option. This means that a same project file could be
displayed differently on different setups...
Best,
Olivier
2014-04-25 14:10 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Nick,
> On Fri, 25. Apr 2014 at 03:53:17 -0700, Nick Hopton wrote:
> > Much obliged Jürgen. After updating QGIS I opened a project that I'd been
> > working on to find a screen full of 'NULL' labels, which worried me a
> > little. The default setting must have changed, I've changed it back now.
> No, it didn't.
> It just wasn't considered for labels.  NULL string values were implicitly
> converted to empty strings, but NULL in numeric fields to 0.  At least the
> latter is wrong - IMHO the former is too, although that also might have
> been
> considered a feature by some.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140425/312fc9b2/attachment.html>
