[Qgis-user] Can Geoserver use the legends of a QGIS project like qgis server
Andreas Neumann
a.neumann at carto.net
Fri Apr 25 07:11:19 PDT 2014
If your WMS is from an external source you obviously have no choice -
you have to cascade these layers through WMS.
If we are talking about layers that are under your own control you could
do the cascading from one project to the other either through WMS (in
which case your requests would generate subsequent WMS requests in your
own QGIS server) or you could use the embedded groups/layers feature,
which is faster, and generates only a single WMS request. Obviously this
is faster, if you think about it.
There is a german article on this issue (you can use google translate)
that shows the performance effect. See
http://sogeo.ch/blog/2014/01/29/qgis-server-vs-qgis-server/
I use the embedded layers and groups for most of my base-maps: the
cadastral base map, a scale-series of raster maps and other base-maps
that are used in multiple projects.
It makes sense to have several QGIS projects as "themes" - but the
projects can link to each other (see menu "Layer" -> "Embed layers and
groups"). QWC has a theme-switcher, which is easier than switching
multiple layers. Often, different themes also need different titles and
legends in the print templates.
The "embed layers and groups" is a powerful feature that many QGIS users
aren't aware of. There had been issues in the past with layer order, if
both projects had a user-defined layer order that was different than the
layer order in the legend tree, but this is now mostly fixed in master.
Andreas
Am 25.04.2014 13:51, schrieb Carlos da Ponte:
> Andreas would you mind elaborating further on the 'cascading' issue.
> My process to date has been:
> To keep updating streamlined I have one qgis project with all of my layers
> in it.
> - 10% shapefiles
> - 70% MS SQL server layers
> - 20% WMS feeds from government sources & imagery services, or shapefiles on
> the QGIS server that are imported as WMS
> - Total number of layers: 50 or so
> I then use the layer and print filter in the OWS setup (QGIS project
> properties)to then save numerous new projects which then become my themes.
> Obviously I do wonder whether maintaining all of these layers in the project
> might reduce performance, but I'm not sure how else to do it.
> Where does the 'cascading' issue fit in with this example I presented
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-Geoserver-use-the-legends-of-a-QGIS-project-like-qgis-server-tp5137088p5137181.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
