[Qgis-user] Load a shapefile in Oracle spatial
Andreas Neumann a.neumann at carto.net
Tue Apr 29 05:01:15 PDT 2014
Have you tried with the dbmanager?
You would load the shapefile into your project. Then dbmanager can take
this data and create a new table in Oracle using this data. In DBManager
navigate to your db-connection and use the "Table" -> "Import Layer/File"
Hope this helps.
Andreas
Am 29.04.2014 11:44, schrieb Estevan Barbará:
> Hello
> I'm using QGis 2.2.0 (Valmiera), and have created a Oracle connection.
> Through this connection, I could read and update existing data, but haven't
> found an interface to load a shapefile to a new table.
> Is there a way to do that?
> Regards
> Estevan
> Qgis-user mailing list
