[Qgis-user] Load a shapefile in Oracle spatial
Estevan Barbará
estevan.barbara at gmail.com
Tue Apr 29 05:19:25 PDT 2014
The DB manager only shows the options of postgis and spatial lite. Also,
the database menu only has the options refresh, SQL window and exit, with
no option to access new database.
Em 29/04/2014 09:01, "Andreas Neumann" <a.neumann at carto.net> escreveu:
> Hi,
> Have you tried with the dbmanager?
> You would load the shapefile into your project. Then dbmanager can take
> this data and create a new table in Oracle using this data. In DBManager
> navigate to your db-connection and use the "Table" -> "Import Layer/File"
> Hope this helps.
> Andreas
> Am 29.04.2014 11:44, schrieb Estevan Barbará:
> > Hello
> > I'm using QGis 2.2.0 (Valmiera), and have created a Oracle connection.
> > Through this connection, I could read and update existing data, but
> haven't
> > found an interface to load a shapefile to a new table.
> > Is there a way to do that?
> > Regards
> > Estevan
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140429/ec5156d5/attachment.html>
