[Qgis-user] (1) Unable resize the main GUI window in the vertical direction (2) Labels missing
Andreas Neumann a.neumann at carto.net
Tue Apr 29 23:30:05 PDT 2014
I have never heard that the QGIS main window cannot be resized
vertically. Maybe an issue or setting in your operating system?
Sometimes graphic card settings control the Windows in Windows and have
some weird side effects.
As to the "labels missing". You will have to describe your problem in
more details or we cannot help. As an example - is polygon
simplification turned on? Or on-the-fly reprojection? Any issues with
min/max scales or rules?
Best would be if you share your project and some sample data
demonstrating the issue.
Andreas
Am 30.04.2014 05:16, schrieb Nadarajah Thirugnanasothy:
> On Tuesday, 29 April 2014, 11:49, Nadarajah Thirugnanasothy <vnthiru at yahoo.co.uk> wrote:
> Hi,
> Running QGIS version 2.2.0-Valmiera (64bit version ) on Windows 7 (64 bit version).
> Any help to resolve the two problems described below would be much appreciated.
> (2) Labels missing
> I am having problem in labelling as described in http://osgeo-org.1560.x6.nabble.com/Missing-labels-in-polygons-td5129966.html
> After reading the above link I tried zooming to see if I can see the label - no luck.
> Tried all the workaround as described in http://gis.stackexchange.com/questions/12758/when-labelling-polygons-not-all-labels-are-displayed-qgis-1-7-0  - No luck
> Thank you.
> Regards
> Thiru
> Qgis-user mailing list
