[Qgis-user] (1) Unable resize the main GUI window in the vertical direction (2) Labels missing
Bob and Deb bobdebm at gmail.com
Wed Apr 30 00:25:41 PDT 2014
This has happened to me after installing a plugin that docks a widget and
makes the main window larger.  If you try to resize at the top of the
window, it might jump down then back up when you release the mouse.
Bob
On Apr 29, 2014 11:30 PM, "Andreas Neumann" <a.neumann at carto.net> wrote:
> Hi,
> I have never heard that the QGIS main window cannot be resized
> vertically. Maybe an issue or setting in your operating system?
> Sometimes graphic card settings control the Windows in Windows and have
> some weird side effects.
> As to the "labels missing". You will have to describe your problem in
> more details or we cannot help. As an example - is polygon
> simplification turned on? Or on-the-fly reprojection? Any issues with
> min/max scales or rules?
> Best would be if you share your project and some sample data
> demonstrating the issue.
> Andreas
> Am 30.04.2014 05:16, schrieb Nadarajah Thirugnanasothy:
> > On Tuesday, 29 April 2014, 11:49, Nadarajah Thirugnanasothy <
> vnthiru at yahoo.co.uk> wrote:
> > Hi,
> > Running QGIS version 2.2.0-Valmiera (64bit version ) on Windows 7 (64
> bit version).
> > Any help to resolve the two problems described below would be much
> appreciated.
> > (2) Labels missing
> > I am having problem in labelling as described in
> http://osgeo-org.1560.x6.nabble.com/Missing-labels-in-polygons-td5129966.html
> > After reading the above link I tried zooming to see if I can see the
> label - no luck.
> > Tried all the workaround as described in
> http://gis.stackexchange.com/questions/12758/when-labelling-polygons-not-all-labels-are-displayed-qgis-1-7-0 - No luck
> > Thank you.
> > Regards
> > Thiru
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140430/2995e505/attachment.html>
