[Qgis-user] auto update listed categories in a legend
Alexandre Neto senhor.neto at gmail.com
Wed Apr 30 06:56:56 PDT 2014
Hello,
I can confirm this problem. Maybe we should create a bug report?
To solve this I generally use a workaround.
Selected the desired Layer\Groupclick the Sum symbol (the one used to show
the number of features for each class). This will update the classes. After
that you can click it again to remove the feature counting.
Best Regards,
Alexandre Neto
On Tue, Apr 29, 2014 at 8:05 PM, Carlos da Ponte <
cdaponte at sustainableelements.ca> wrote:
> Hi all,
> If i have a layer styled using categories based on a given field in that
> layer (its a database layer), as I add new entries to the database which
> may
> result in more 'categories' in that layer, is there a way for the legend to
> automatically update.  Eg. the layer is styled using field "Owner".  After
> the initial classification is done on this layer, additional 'Owner's are
> added (and therefore new categories) causing the layer style to not be up
> to
> date (missing categories).
> any ideas?
> C
> http://osgeo-org.1560.x6.nabble.com/auto-update-listed-categories-in-a-legend-tp5137843.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140430/1b6fe8ac/attachment.html>
