[Qgis-user] Points layer from table tool truncating texts
anderso at anlaggarna.se anderso at anlaggarna.se
Wed Dec 3 03:59:47 PST 2014
Thank you for helping out.
Comments below:
> Did you create the layer as a temporary one? So then its stored as an ESRI
> shape and the dbf will not store more characters.
Used temporary before and i understand the problem better now.
> Or did you also try to save it directly into another format which supports
> longer fields (errm, here I'm lost too, cause I do not know most of the
> formats available, but maybe try sqlite)
I've tried "all" possible file-formats that can be selected in the "Points
Layer from Table" tool and it seems like they all store the result like
shape files (using a dbf database file).
Selecting sqlite-format:
sqll.sqlit.dbf
sqll.sqlit.prj
sqll.sqlit.qbj
sqll.sqlit.shp
sqll.sqlit.shx
I'm rather confused here, i expected to find raw files with the selected
format as output?
So this is leading in the direction that i can't use the tool if i want
longer text fields.
Some other ideas (partly evaluated):
- The EVIS database tools seem to support longer strings but have issues
with national characters and fails to add all points "missing georeference
infomation)?
- The "SAGA convert table to points" seems to be missing/removed in QGIS?
> Cheers
> Bernd
Thanks
/AO
> Am 03.12.2014, 10:07 Uhr, schrieb <anderso at anlaggarna.se>:
>> Hi!
>> I'm having a problem with the "Points Layer from Table" tool.
>> The source data contain string/text data longer than 255 characters
>> (memo
>> fields from MS Access)
>> The fields are truncated to 255 characters in the resulting point layer
>> when looking in the "attribute table window"
>> When opening the source data layer in the "attribute table window" the
>> fields are not truncated so the problem must be in the tool itself.
>> The source layer is created using "create vector
>> layer->Database->ODBC->...."
>> Does anyone have a workaround for this?
>> I found some tips about using the SAGA "create points from table" tool
>> instead but i can't find it in QGIS?
>> I'm using QGIS 2.6.1
>> BR
>> /AO
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
