[Qgis-user] Map labeling (through MSSQL)
Francisco José Hernández Medialdea franhm at gmail.com
Thu Dec 4 00:29:51 PST 2014
Dear all,
I'm trying to put labels into a layer formed by an SQL Server table where I
obtain a scoring (float format) for each polygon, its identifier and its
GEOM reference. I was succesfull in colouring every part of the map based
on a scale, depending on that score. Now, my purpose is to show the same
score on top of the layer. I procceeded as described in several tutorials
but was unsuccessful. In fact, just one label out of 19 appears initially
on the map. Then, zooming in and moving randomly around the map area, at
least apparently, some other (score labels) appear, although some others
disappear. Can it be motivated by using an SQL table as layer source? How
can I transform it, in case it is posible to, into a SHP file to come over
and try to label it again, afterwards?
Many thanks in advance for your help.
Fran
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141204/d781ac55/attachment.html>
