[Qgis-user] Map labeling (through MSSQL)
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Thu Dec 4 03:14:38 PST 2014
Hi Fran,
did you try checking the box "Show all labels for this layer (including
colliding labels) and unckecking "Discourage labels from covering
features" under "Rendering" in the Label settings?
I don't think (though no real expertise) that it has to do with your data
provider.
Cheers
Bernd
Am 04.12.2014, 09:29 Uhr, schrieb Francisco José Hernández Medialdea
<franhm at gmail.com>:
> Dear all,
> I'm trying to put labels into a layer formed by an SQL Server table
> where I obtain a scoring (float format) for each polygon, its identifier
> and its GEOM >reference. I was succesfull in colouring every part of the
> map based on a scale, depending on that score. Now, my purpose is to
> show the same score >on top of the layer. I procceeded as described in
> several tutorials but was unsuccessful. In fact, just one label out of
> 19 appears initially on the map. >Then, zooming in and moving randomly
> around the map area, at least apparently, some other (score labels)
> appear, although some others disappear. >Can it be motivated by using an
> SQL table as layer source? How can I transform it, in case it is posible
> to, into a SHP file to come over and try to label >it again, afterwards?
> Many thanks in advance for your help.
> Fran
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141204/74814e70/attachment.html>
