[Qgis-user] Cannot open GML files in Qgis 2.6 under Windows
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Dec 4 05:59:49 PST 2014
Try using the .shp. Should work. .GML support is partial. http://www.gdal.org/drv_gml.html and not all versions are supported. It's a touchy format.
As for the 2 libraries ( Xerces and libexpat) I am not sure. If you are using using the Osgeo installer try looking for them using the advanced installer. If all else fails, install a stand alone version of Gdal using the latest version and try converting the file using ogr2ogr at the command prompt.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2014-12-04 06:54, "ademey [via OSGeo.org]" <ml-node+s1560n5176441h32 at n6.nabble.com> a écrit :
Hello,
I am looking into ways to get legend info for data provide by the
Flemish government (agiv download portal) into qgis.
Excuse me if similar questions were asked before, I could nog find much
help in the e-mail archives.
Data is provide in ESRI shapefiles as well as GML files.
- Shapefiles come with .lyr of .avl (old format) files - you know that.
As far as I know, I cannot use these with Qgis (.qml or .SLD files needed).
- GML files are an open OGC standard format, and everywhere I find Qgis
should be able to open them.
When I try to open .gml files, I get a table, no geometry (nothing is
mapped). I have a windows install of Qgis 2.6. Are there any additional
plugins or libraries needed to make this work?
I found in this link ( http://www.gdal.org/ogr_formats.html ) that read
support needs Xerces or libexpat. Do these come with Qgis install? How
can I check wether I have these or how I should install these?
Thanks in advance!
Andreas Demey
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Cannot-open-GML-files-in-Qgis-2-6-under-Windows-tp5176441.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-open-GML-files-in-Qgis-2-6-under-Windows-tp5176441p5176472.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141204/be0dde33/attachment.html>
