[Qgis-user] Qgis uninstall Osx
Major Balázs
mballer at gmail.com
Thu Dec 4 08:28:23 PST 2014
Dear All,
I had some problem with processing modeler under Osx, Qgis 2.6. As I wrote before, some algorithm did not work properly in the modeler. I was not able to use the join attribute algorythm, because for layer 2 it was unable to chose a vector layer from the drop down menu.
So I uninstalled 2.6, (deleted qgis from application folder, deleted .qgis2 folder) and installed 2.4 again. My problem has gone. In the modeler the join attribute works again. BUT
It still shows the recently used algorithms, which I used with the 2.6
My question is. How can I totally uninstall qgis and make a new clean install under osx 10.9? I think the modeler didnt work under 2.6 because some parts remained from older version.
Thanx,
Balazs
