[Qgis-user] Qgis uninstall Osx
William Kyngesburye woklist at kyngchaos.com
Thu Dec 4 15:32:34 PST 2014
For executable parts of QGIS, the application and the ~/.qgis2 folder are all there is.  There are Python modules (matplotlib, etc.), but those are separate from QGIS, and both versions of QGIS use the same versions of those Python modules.
The readme does say it's best to delete any existing QGIS app before installing another.  But nothing about deleting old QGIS plugin junk in .qgis2 (I thought I had something in the readme about this, maybe I did once), it can be tricky for the average user to manage (I have a standing request to move this folder to users' Application Support on OS X).
There are preferences in ~/Library/Preferences (org.qgis.something.plist), this is probably where the history of what algorithms were used is stored, but would have nothing to do with what algorithms are currently installed, it's just a record of the past.
On Dec 4, 2014, at 10:28 AM, Major Balázs <mballer at gmail.com> wrote:
> Dear All,
> I had some problem with processing modeler under Osx, Qgis 2.6. As I wrote before, some algorithm did not work properly in the modeler. I was not able to use the join attribute algorythm, because for layer 2 it was unable to chose a vector layer from the drop down menu.
> So I uninstalled 2.6, (deleted qgis from application folder, deleted .qgis2 folder) and installed 2.4 again. My problem has gone. In the modeler the join attribute works again. BUT
> It still shows the recently used algorithms, which I used with the 2.6
> My question is. How can I totally uninstall qgis and make a new clean install under osx 10.9? I think the modeler didnt work under 2.6 because some parts remained from older version.
> Thanx,
> Balazs
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
