[Qgis-user] [Plugin][qgis2threejs] Set the elevation base of the model with the first value of DEM
João Gaspar
joao.f.r.gaspar at gmail.com
Thu Dec 4 10:45:18 PST 2014
Hi guys,
it's is possible set the base o f the 3d model to the first value of the
DEM?
Imagine this, i have a dem clip that starts with elevation 265 meters and
goes to 327 meters.
When i run the qgis2threejs the output start from 0 meters (i guess that is
the surface above water) and give me a "big exaggeration" of the model.
If i change the exaggeration factor to small factors such as 0.01, 0.05 to
reduce the exageration of the model (provoked by the 0 meters) but the
model became to smooth and lose the detail of the terrain.
Another thing the nodata values in this case is -9999, this could be a
problem?
Best Regards,
João
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141204/e5effb4d/attachment.html>
