[Qgis-user] Map Composer and Attributes from a layer
Randal Hale rjhale at northrivergeographic.com
Sun Dec 7 12:08:29 PST 2014
That does give me a workaround of sorts....
Is there any way to pull from a table and place the information in
composer - a table that isn't being used by Atlas?
.....But Alexandre's idea might give me a work around in the meantime.
On 12/07/2014 01:20 PM, Alexandre Neto wrote:
> Hello Randal,
> You are looking for the atlas generation feature.
> In the map composer go to the atlas tab and set your layer as atlas
> coverage layer. (Don't forget to turn atlas control on your map item
> properties). From that point on, you can use the coverage layer's
> attributes in labels usig the expression builder, or simply set the
> label as:
> [%my_column%]
> Hope I helped.
> Alexandre Neto
> On Sun, Dec 7, 2014 at 4:49 PM, Randal Hale
> <rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>> wrote:
>     Is it possible to insert an attribute into map composer? I'm
>     thinking it is but I'm stumbling just a bit.
>     I have a layer that will change through time. I want to insert the
>     name of the polygon into map composer with the area as part of
>     some text at the bottom of the map. I am thinking I use the
>     getFeature and/or the attribute function to insert an expression -
>     but I'm not entirely sure.
>     I'm pulling the data from postgis so I can create a view with just
>     that one polygon if that helps.
>     Thanks so much - not that it probably matters but Ubuntu 14.04
>     QGIS 2.6.1
>     Randy
>     Randal Hale
>     North River Geographic Systems, Inc
>     http://www.northrivergeographic.com
>     423.653.3611 <tel:423.653.3611> rjhale at northrivergeographic.com
>     twitter:rjhale http://about.me/rjhale
>     http://www.northrivergeographic.com/spatial-connect
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
423.653.3611 rjhale at northrivergeographic.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141207/bfb5271e/attachment.html>
