[Qgis-user] Map Composer and Attributes from a layer
Randal Hale rjhale at northrivergeographic.com
Sun Dec 7 08:49:14 PST 2014
Is it possible to insert an attribute into map composer? I'm thinking it
is but I'm stumbling just a bit.
I have a layer that will change through time. I want to insert the name
of the polygon into map composer with the area as part of some text at
the bottom of the map. I am thinking I use the getFeature and/or the
attribute function to insert an expression - but I'm not entirely sure.
I'm pulling the data from postgis so I can create a view with just that
one polygon if that helps.
Thanks so much - not that it probably matters but Ubuntu 14.04 QGIS 2.6.1
Randy
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale     http://about.me/rjhale
http://www.northrivergeographic.com/spatial-connect
