[Qgis-user] recurrent PythonError. What is wrong?
Enrico Ferreguti
enricofer at gmail.com
Sun Dec 7 13:42:11 PST 2014
I think you installed the plugin without having blank project. existing
layers were not registered to the plugin that try to hooks to change layer
signals (fired on every event you describe)
I would try to close your current project before reinstall plugin or simply
restart qgis after install it.
regards
Enrico Ferreguti
Il giorno 07/dic/2014, alle ore 20:47, Joris Hintjens <jorishin at gmail.com>
ha scritto:
Hello Nicolas and Enrico,
I uninstalled the plugin and rebooted. Everything seems to work well now.
Thanks for the help.
For Enrico: I had the message since my upgrade to 2.6, but i installed all
my plugins at the same time. SO for me no way to say if the bug is in the
2.6 part or the plugin part.
Joris
Op 7-dec.-2014, om 20:08 heeft Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
het volgende geschreven:
I agree with Enrico,
I would uninstall the plugin and see what happens.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2014-12-07 12:05, "enricofer [via OSGeo.org]" <[hidden email]
<x-msg://2/user/SendEmail.jtp?type=node&node=5176793&i=0>> a écrit :
Hi Joris
The message appears to come from attributePainter plugin.
Do you mean this is a new message error that occurs after your system or
qgis update or is it an error that happens after the plugin installation?
Regards
Enrico Ferreguti
Il giorno 07/dic/2014, alle ore 17:01, Joris Hintjens <[hidden email]
<x-msg://2/user/SendEmail.jtp?type=node&node=5176785&i=0>> ha scritto:
> Hello,
> Running QGIS 2.6 on OS10.10yosemite,
> Every time I change something in the layer pane (move, toggle on/of, add
or detail a layer, I encounter recurrent errormessages. what is wrong?
> Traceback (most recent call last):
> File
"/Users/joris/.qgis2/python/plugins/attributePainter/attributepainter.py",
line 152, in checkOnLayerChange
> self.layerHighlighted.editingStarted.disconnect(self.checkEditable)
> RuntimeError: wrapped C/C++ object of type QgsVectorLayer has been
deleted
> Any suggestions what this might be and how to deal with this?
> thanks
> Qgis-user mailing list
> [hidden email] <x-msg://2/user/SendEmail.jtp?type=node&node=5176785&i=1>
[hidden email] <x-msg://2/user/SendEmail.jtp?type=node&node=5176785&i=2>
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1560.x6.nabble.com/recurrent-PythonError-What-is-wrong-tp5176781p5176785.html
To start a new topic under Quantum GIS - User, email [hidden email]
<x-msg://2/user/SendEmail.jtp?type=node&node=5176793&i=1>
To unsubscribe from Quantum GIS - User, click here.
NAML
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: recurrent PythonError. What is wrong?
<http://osgeo-org.1560.x6.nabble.com/recurrent-PythonError-What-is-wrong-tp5176781p5176793.html>
Sent from the Quantum GIS - User mailing list archive
<http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
Nabble.com.
Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141207/1f4f8fd3/attachment.html>
