[Qgis-user] Which Projection to use?
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Dec 8 13:50:39 PST 2014
Your easiest bet is to use WGS84 with UTM Zones.  It covers the planet,
and the UTM zones are meter.   See attachments for the zones.  Ex: EPSG
32618 = WGS84 / UTM18N
Nicolas
Le 2014-12-08 16:09, K.Bott [via OSGeo.org] a écrit :
> Hi Joris,
> One starting point might be here --
> http://www.radicalcartography.net/index.html?projectionref -- expand
> the categories for a sense of what they translate to in terms of visuals.
> cheers -
> -kristin
> On Mon, Dec 8, 2014 at 11:23 AM, Joris Hintjens <[hidden email]
> </user/SendEmail.jtp?type=node&node=5176943&i=0>> wrote:
>     Hello,
>     My problem:
>     I have to create a series of maps all around the world. For each
>     map, I need a appropriate CRS in meters (t create buffers etc…)
>     Does anybody know a source out there where I can see the extends
>     of existing projections I can use for each map?
>     I keep bouncing up to http://spatialreference.org/ , but the list
>     is of no use to me, as there is no map.
>     thanks
>     Joris
>     _______________________________________________
>     Qgis-user mailing list
>     [hidden email] </user/SendEmail.jtp?type=node&node=5176943&i=1>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email] </user/SendEmail.jtp?type=node&node=5176943&i=2>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Which-Projection-to-use-tp5176939p5176943.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
World_UTM_WGS84.zip (199K) <http://osgeo-org.1560.x6.nabble.com/attachment/5176949/0/World_UTM_WGS84.zip>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Which-Projection-to-use-tp5176939p5176949.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141208/93ee7acb/attachment.html>
