[Qgis-user] Which Projection to use?
Joris Hintjens jorishin at gmail.com
Tue Dec 9 04:14:27 PST 2014
thanks Kristin and Nicolas,
Now I get which UTM zone I’ min, and I’ve been spending the last hours in trying to find the corresponding EPSG code and/or the proj4  code to enter in QGIS. they are not listed in the default list in Qgis
Any suggestions welcome
Joris
> Op 8-dec.-2014, om 22:50 heeft Nicolas Cadieux <nicolas.cadieux at archeotec.ca> het volgende geschreven:
> Hi,
> Your easiest bet is to use WGS84 with UTM Zones.  It covers the planet, and the UTM zones are meter.   See attachments for the zones.  Ex: EPSG 32618 = WGS84 / UTM18N
> Nicolas
> Le 2014-12-08 16:09, K.Bott [via OSGeo.org] a écrit :
>> Hi Joris,
>> One starting point might be here -- http://www.radicalcartography.net/index.html?projectionref <http://www.radicalcartography.net/index.html?projectionref> -- expand the categories for a sense of what they translate to in terms of visuals.
>> cheers -
>> -kristin
>> On Mon, Dec 8, 2014 at 11:23 AM, Joris Hintjens <[hidden email] <x-msg://2/user/SendEmail.jtp?type=node&node=5176943&i=0>> wrote:
>> Hello,
>> My problem:
>> I have to create a series of maps all around the world. For each map, I need a appropriate CRS in meters (t create buffers etc…)
>> Does anybody know a source out there where I can see the extends of existing projections I can use for each map?
>> I keep bouncing up to http://spatialreference.org/ <http://spatialreference.org/> , but the list is of no use to me, as there is no map.
>> thanks
>> Joris
>> Qgis-user mailing list
>> [hidden email] <x-msg://2/user/SendEmail.jtp?type=node&node=5176943&i=1>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>> [hidden email] <x-msg://2/user/SendEmail.jtp?type=node&node=5176943&i=2>
>> If you reply to this email, your message will be added to the discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Which-Projection-to-use-tp5176939p5176943.html <http://osgeo-org.1560.x6.nabble.com/Which-Projection-to-use-tp5176939p5176943.html>
>> To start a new topic under Quantum GIS - User, email [hidden email] <x-msg://2/user/SendEmail.jtp?type=node&node=5176949&i=0>
>> To unsubscribe from Quantum GIS - User, click here <applewebdata://047E9CC2-6620-4E09-80E2-00F31BF8281B>.
>> NAML <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>  World_UTM_WGS84.zip (199K) Download Attachment <http://osgeo-org.1560.x6.nabble.com/attachment/5176949/0/World_UTM_WGS84.zip>
> View this message in context: Re: Which Projection to use? <http://osgeo-org.1560.x6.nabble.com/Which-Projection-to-use-tp5176939p5176949.html>
> Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141209/ef8dfc2a/attachment.html>
