[Qgis-user] Which Projection to use?
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Dec 9 07:43:55 PST 2014
They are there in QGIS. Filter for WGS84 in the CSR and you will find them.  That's how I got the code I gave you below.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2014-12-09 07:14, "Joris Hintjens [via OSGeo.org]	" <ml-node+s1560n5177018h19 at n6.nabble.com> a écrit :
	thanks Kristin and Nicolas, Now I get which UTM zone I’ min, and I’ve been spending the last hours in trying to find the corresponding EPSG code and/or the proj4  code to enter in QGIS. they are not listed in the default list in Qgis Any suggestions welcome Joris   Op 8-dec.-2014, om 22:50 heeft Nicolas Cadieux < [hidden email] > het volgende geschreven:
    Your easiest bet is to use WGS84 with UTM Zones.  It covers the
    planet, and the UTM zones are meter.   See attachments for the
    zones.  Ex: EPSG 32618 = WGS84 / UTM18N
    Nicolas
    Le 2014-12-08 16:09, K.Bott [via
      OSGeo.org ] a écrit :
    <blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' style="border-left:2px solid #CCCCCC;padding:0 1em" cite="mid:CAPvLB7+Sd9RjhKwY-iNX02_RgvdzW7Z1BGQgL7wqCZ20q1hyfw at mail.gmail.com" type="cite" class="">
      Hi Joris,
        One starting point might be here --  http://www.radicalcartography.net/index.html?projectionref
          -- expand the categories for a sense of what they translate to
          in terms of visuals.
        cheers -
        -kristin
        On Mon, Dec 8, 2014 at 11:23 AM, Joris
          Hintjens <<a moz-do-not-send="true" href="x-msg://2/user/SendEmail.jtp?type=node&amp;node=5176943&amp;i=0" target="_top" rel="nofollow" link="external" class="">[hidden
              email] > wrote:
          <blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' style="border-left:2px solid #CCCCCC;padding:0 1em" class="gmail_quote">
            Hello,
              My problem:
              I have to create a series of maps all around the
                world. For each map, I need a appropriate CRS in meters
                (t create buffers etc…)
              Does anybody know a source out there where I can see
                the extends of existing projections I can use for each
                map?
              I keep bouncing up to  http://spatialreference.org/  ,
                but the list is of no use to me, as there is no map.
              thanks
                  Joris
            Qgis-user mailing list
            <a moz-do-not-send="true" href="x-msg://2/user/SendEmail.jtp?type=node&amp;node=5176943&amp;i=1" target="_top" rel="nofollow" link="external" class="">[hidden
              email]
            http://lists.osgeo.org/mailman/listinfo/qgis-user
      <a moz-do-not-send="true" href="x-msg://2/user/SendEmail.jtp?type=node&amp;node=5176943&amp;i=2" target="_top" rel="nofollow" link="external" class="">[hidden email]
        If you reply to this email, your
          message will be added to the discussion below:
        http://osgeo-org.1560.x6.nabble.com/Which-Projection-to-use-tp5176939p5176943.html
        To start a new topic under Quantum GIS - User, email
        <a href="x-msg://2/user/SendEmail.jtp?type=node&amp;node=5176949&amp;i=0" target="_top" rel="nofollow" link="external" class="">[hidden email]
        To unsubscribe from Quantum GIS - User, click
          here .
        NAML
 World_UTM_WGS84.zip (199K) Download Attachment
View this message in context: Re: Which Projection to use?
Sent from the Quantum GIS - User mailing list archive  at Nabble.com . _______________________________________________ Qgis-user mailing list [hidden email] http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Which-Projection-to-use-tp5176939p5177018.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Which-Projection-to-use-tp5176939p5177058.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141209/46db5776/attachment.html>
