[Qgis-user] How load Postgis layer from command line?
Richard Duivenvoorde
rdmailings at duif.net
Tue Dec 9 12:39:01 PST 2014
On 09-12-14 16:41, Germán Carrillo wrote:
> Hi Richard,
> thanks a lot for your response. However, I think we aren't talking about
> the same :)
> I understand this thread was opened to ask about how to open a PostGIS
> Layer from the OS (say GNU/Linux) command line at QGIS startup.
ah, sorry sorry :-(
well, I take this as a challenge...
(short version: go to the end, either use a vrt file or a qgs file)
looking into the code:
https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.cpp#L4206
it looks like you can only use ogr provider for this...
here:
http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/loadlayer.html
there is an example to use a MySQL uri... so I tried that one first.
All is based on ogr, so we need the ogr driver:
http://www.gdal.org/drv_pg.html
tried stuff like:
PG:'dbname=bag host=localhost port=5432 user=geo
password=xxx sslmode=disable key=gid estimatedmetadata=true srid=28992
type=MULTIPOLYGON table="bag8mrt2014"."provincie" (geovlak) sql='
but all that I got working was a simple:
ogrinfo -ro PG:'host=localhost user=geo password=gwwvgeo dbname=bag
sslmode=disable'
but using that kind of uri's did not make QGIS load, it kept showing:
Unable to load /tmp/PG:host=localhost user=geo password=xxx dbname=bag
sslmode=disable
apparently QGIS ALWAYS prepends the basepath (/tmp for me) in front of
the 'filename'. It has to be a real file ??
THEN: ok, so it has to be ogr AND a file...
There is gdal's Virtual Format:
http://www.gdal.org/drv_vrt.html
so with some trial and error I prepared the following vrt file, for
exact the same data as the earlier email:
<OGRVRTDataSource>
<OGRVRTLayer name="test">
<SrcDataSource>PG:host=localhost user=geo password=*** dbname=bag
sslmode=disable</SrcDataSource>
<SrcSQL>select * from bag8mrt2014.provincie</SrcSQL>
<LayerSRS>epsg:28992</LayerSRS>
</OGRVRTLayer>
</OGRVRTDataSource>
saved it as mypgconnection.vrt, and NOW I can load it with:
qgis mypgconnection.vrt \o/
another option, is to create a qgs project file with that postgresql
connection and fire up qgis with that one
qgis mypgproject.qgs
you could maybe create the qgs file dynamically to have your
schema/table names in place
ok, it's all a little hacking, but hopefully of use :-)
Regards,
