[Qgis-user] How load Postgis layer from command line?
Larry Shaffer larrys at dakotacarto.com
Tue Dec 9 15:17:19 PST 2014
HI,
Another thing you might try is this command line option:
[--code path] run the given python file on load
Then, you could possibly load the PostGIS layer just as you would from the
PyQGIS console, only it would be commands inside of a Python file.
You could do other things as well, like verify the PostgreSQL server is up,
etc.
Please note: just guessing here, as I have not fully tested this yet.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Tue, Dec 9, 2014 at 1:39 PM, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 09-12-14 16:41, Germán Carrillo wrote:
> > Hi Richard,
> > thanks a lot for your response. However, I think we aren't talking about
> > the same :)
> > I understand this thread was opened to ask about how to open a PostGIS
> > Layer from the OS (say GNU/Linux) command line at QGIS startup.
> ah, sorry sorry :-(
> well, I take this as a challenge...
> (short version: go to the end, either use a vrt file or a qgs file)
> looking into the code:
> https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.cpp#L4206
> it looks like you can only use ogr provider for this...
> here:
> http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/loadlayer.html
> there is an example to use a MySQL uri... so I tried that one first.
> All is based on ogr, so we need the ogr driver:
> http://www.gdal.org/drv_pg.html
> tried stuff like:
> PG:'dbname=bag host=localhost port=5432 user=geo
> password=xxx sslmode=disable key=gid estimatedmetadata=true srid=28992
> type=MULTIPOLYGON table="bag8mrt2014"."provincie" (geovlak) sql='
> but all that I got working was a simple:
> ogrinfo -ro PG:'host=localhost user=geo password=gwwvgeo dbname=bag
> sslmode=disable'
> but using that kind of uri's did not make QGIS load, it kept showing:
> Unable to load /tmp/PG:host=localhost user=geo password=xxx dbname=bag
> sslmode=disable
> apparently QGIS ALWAYS prepends the basepath (/tmp for me) in front of
> the 'filename'. It has to be a real file ??
> THEN: ok, so it has to be ogr AND a file...
> There is gdal's Virtual Format:
> http://www.gdal.org/drv_vrt.html
> so with some trial and error I prepared the following vrt file, for
> exact the same data as the earlier email:
> <OGRVRTDataSource>
> <OGRVRTLayer name="test">
> <SrcDataSource>PG:host=localhost user=geo password=*** dbname=bag
> sslmode=disable</SrcDataSource>
> <SrcSQL>select * from bag8mrt2014.provincie</SrcSQL>
> <LayerSRS>epsg:28992</LayerSRS>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> saved it as mypgconnection.vrt, and NOW I can load it with:
> qgis mypgconnection.vrt  \o/
> another option, is to create a qgs project file with that postgresql
> connection and fire up qgis with that one
> qgis mypgproject.qgs
> you could maybe create the qgs file dynamically to have your
> schema/table names in place
> ok, it's all a little hacking, but hopefully of use :-)
> Regards,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141209/997c8544/attachment.html>
