[Qgis-user] Spatialite queries return text instead of numeric values
Alexandre Neto senhor.neto at gmail.com
Wed Dec 10 10:57:26 PST 2014
Hello all,
To make some tests I have the folllowing table:
General info
  Relation type:
Table
Rows:
3
SpatiaLite
  Column:
geometry
Geometry:
MULTIPOLYGON
Dimension:
XY
Spatial ref:
WGS 84 (4326)
Extent:
(unknown) (find out <action:extent/get>)
Fields
Name
Type
Null
Default
0
pkuid
integer
Y
1
coluna1
text
Y
2
coluna2
real
Y
3
coluna3
integer
Y
4
geometry
MULTIPOLYGON
Y
If I do this:
SELECT
    coluna2/1.0 AS test_field
FROM
    testes
when I open it with DBmanager the test_field return a QSTRING with type
name TEXT
http://imgur.com/GHeMyiW
Using cast:
 SELECT
    cast((coluna2/1.0) as real) AS test_field
FROM
    testes
I get the same.
Thanks for the help.
Alexandre Neto
On Wed, Dec 10, 2014 at 6:16 PM, Alex Mandel <tech_dev at wildintellect.com>
wrote:
> On 12/10/2014 09:55 AM, Goyo wrote:
> > 2014-12-10 1:50 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
> >> Hello,
> >> When querying a spatialite database in the database manager, if you
> create
> >> some calculations (say add two columns values) the resulting column
> returns
> >> as TEXT instead of the expected numeric field.
> >> Is this intended or a bug?
> >> Trying to cast it as real, double or float did not work either.
> > Calculated columns in SQLite do not have a data type, the actual
> > values in the column do. If you execute this query:
> > SELECT "col1" + "col2" AS "thevalue", typeof("col1" + "col2") as
> > "thetype" FROM "table"
> > You should have "thetype"='real' in every row (provided "col1" and
> > "col2" always contain real values) but the column "thevalue" does not
> > have a data type assigned.
> > I guess QGIS needs to assign a data type to each column and chooses
> > the more general type when the column does not have one without
> > looking at the actual values (which could be expensive and also
> > misleading if the data change).
> > Goyo
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> There are two ways in SQLITE to get the numeric type you want, you can
> do a CAST() or you can force it with a multiplication (*1 or *1.0). It's
> really critical if you do a division to *1.0 somewhere in the statement
> otherwise you'll only get an integer.
> Note this is not a QGIS specific thing, it applies to general use of
> SQLITE.
> You said you tried a CAST, can you paste what you tried?
> Thanks,
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141210/3d3062b8/attachment.html>
