[Qgis-user] Spatialite queries return text instead of numeric values
Alex Mandel tech_dev at wildintellect.com
Wed Dec 10 11:02:19 PST 2014
What happens if you CREATE VIEW with those tests?
Does QGIS read the VIEW differently?
Thanks,
Alex
On 12/10/2014 10:57 AM, Alexandre Neto wrote:
> Hello all,
> To make some tests I have the folllowing table:
> General info
>   Relation type:
> Table
> Rows:
> 3
> SpatiaLite
>   Column:
> geometry
> Geometry:
> MULTIPOLYGON
> Dimension:
> XY
> Spatial ref:
> WGS 84 (4326)
> Extent:
> (unknown) (find out <action:extent/get>)
> Fields
> Name
> Type
> Null
> Default
> 0
> pkuid
> integer
> Y
> 1
> coluna1
> text
> Y
> 2
> coluna2
> real
> Y
> 3
> coluna3
> integer
> Y
> 4
> geometry
> MULTIPOLYGON
> Y
> If I do this:
> SELECT
>     coluna2/1.0 AS test_field
> FROM
>     testes
> when I open it with DBmanager the test_field return a QSTRING with type
> name TEXT
> http://imgur.com/GHeMyiW
> Using cast:
>  SELECT
>     cast((coluna2/1.0) as real) AS test_field
> FROM
>     testes
> I get the same.
> Thanks for the help.
> Alexandre Neto
> On Wed, Dec 10, 2014 at 6:16 PM, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
>> On 12/10/2014 09:55 AM, Goyo wrote:
>>> 2014-12-10 1:50 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
>>>> Hello,
>>>> When querying a spatialite database in the database manager, if you
>> create
>>>> some calculations (say add two columns values) the resulting column
>> returns
>>>> as TEXT instead of the expected numeric field.
>>>> Is this intended or a bug?
>>>> Trying to cast it as real, double or float did not work either.
>>> Calculated columns in SQLite do not have a data type, the actual
>>> values in the column do. If you execute this query:
>>> SELECT "col1" + "col2" AS "thevalue", typeof("col1" + "col2") as
>>> "thetype" FROM "table"
>>> You should have "thetype"='real' in every row (provided "col1" and
>>> "col2" always contain real values) but the column "thevalue" does not
>>> have a data type assigned.
>>> I guess QGIS needs to assign a data type to each column and chooses
>>> the more general type when the column does not have one without
>>> looking at the actual values (which could be expensive and also
>>> misleading if the data change).
>>> Goyo
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> There are two ways in SQLITE to get the numeric type you want, you can
>> do a CAST() or you can force it with a multiplication (*1 or *1.0). It's
>> really critical if you do a division to *1.0 somewhere in the statement
>> otherwise you'll only get an integer.
>> Note this is not a QGIS specific thing, it applies to general use of
>> SQLITE.
>> You said you tried a CAST, can you paste what you tried?
>> Thanks,
>> Alex
