[Qgis-user] SAGA toolbox
Mark Coletti mcoletti at gmail.com
Thu Dec 18 11:26:56 PST 2014
As a follow up I am having the *exact same problems* on MacOS.  SAGA runs
from the command line without problems, yet cannot seem to run from within
qgis.  This has been an ongoing problem with qgis for the last two versions
on my machine.  Different versions, same problem.  However, I have been
(maybe?) able to resolve this issue.
This is the error dialog:
[image: Inline image 1]
My OS:
$ uname -a
Darwin cervonepd01.geog.psu.edu 11.4.2 Darwin Kernel Version 11.4.2: Thu
Aug 23 16:26:45 PDT 2012; root:xnu-1699.32.7~1/RELEASE_I386 i386
The "Click here" link takes you here:
http://docs.qgis.org/2.0/en/docs/user_manual/processing/3rdParty.html
The first paragraph reads:
SAGA algorithms can be run from QGIS if you have SAGA installed in your
> system and you configure the processing framework properly so it can find
> SAGA executables. *In particular, the SAGA command-line executable is
> needed to run SAGA algorithms.*
I can run SAGA from the command line, so that's not a problem:
$ which saga_cmd
/opt/local/bin/saga_cmd
$ saga_cmd -h
____________________________
SAGA Version: 2.1.4
Further down, the same web page states:
If you have installed SAGA yourself (remember, you need version 2.1), the
> path to the SAGA executable must be configured. To do it, open the
> configuration dialog. In the *SAGA* block you will find a setting named *SAGA
> Folder*. Enter the path to the folder where SAGA is installed. Close the
> configuration dialog and now you are ready to run SAGA algorithms from QGIS.
There is no "SAGA block" in the current qgis configuration dialog that I
can see.  FWIW, I'm running qgis 2.6.1-Brighton.  There is a "SAGA"
providers option under "Processing Options," but no where to specify a
"SAGA Folder".
However, checking off the "Enable SAGA 2.0.8 compatibility" in appears to
unwedge the SAGA functionality.  (I.e., Processing -> Options and
configuration -> Providers -> Saga -> "Enable SAGA 2.0.8 compatibility") So
apparently that was the actual problem.
On Thu, Jun 26, 2014 at 9:00 AM, john polo <jpolo at mail.usf.edu> wrote:
> On 6/26/2014 6:13 AM, Jonathan Moules wrote:
>> Hi John,
>> I've had this myself in the past. It's a result of the way it has been
>> installed - are you using Windows or Linux? And what version of QGIS?
> Jonathon,
> It's on a Windows machine. The QGIS version is 2.2. I used OSGeo4W
> Advanced Install and installed SAGA via the menus at the same time I
> installed QGIS.
> I started SAGA separately to see if there was something to select or click
> on, but I couldn't find anything helpful.
> Thanks,
> John
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141218/7578b738/attachment.html>
Name: Screen Shot 2014-12-18 at 1.51.44 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141218/7578b738/attachment.png>
