[Qgis-user] SAGA toolbox
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Thu Dec 18 13:01:56 PST 2014
I guess you are tying to use Saga from the processing tool box.  It should be installed if you users the OSGEO installer, it should be there.
You may just need to configure the SAGA folder in QGIS
Processing\options and configuration \ provider \saga \ Saga folder. Mine is set to c:/OSGEO4~1/apps\saga
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2014-12-18 14:27, "Mark Coletti-2 [via OSGeo.org]	" <ml-node+s1560n5178429h60 at n6.nabble.com> a écrit :
	As a follow up I am having the *exact same problems* on MacOS.  SAGA runs from the command line without problems, yet cannot seem to run from within qgis.  This has been an ongoing problem with qgis for the last two versions on my machine.  Different versions, same problem.  However, I have been (maybe?) able to resolve this issue. This is the error dialog: My OS: $ uname -a Darwin cervonepd01.geog.psu.edu  11.4.2 Darwin Kernel Version 11.4.2: Thu Aug 23 16:26:45 PDT 2012; root:xnu-1699.32.7~1/RELEASE_I386 i386 The "Click here" link takes you here:  http://docs.qgis.org/2.0/en/docs/user_manual/processing/3rdParty.html    The first paragraph reads: <blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' class="gmail_quote" style="margin:0px 0px 0px 0.8ex;border-left-width:1px;border-left-color:rgb(204,204,204);border-left-style:solid;padding-left:1ex">SAGA algorithms can be run from QGIS if you have SAGA installed in your system and you configure the processing framework properly so it can find SAGA executables. In particular, the SAGA command-line executable is needed to run SAGA algorithms. I can run SAGA from the command line, so that's not a problem: $ which saga_cmd /opt/local/bin/saga_cmd $ saga_cmd -h ____________________________    #####   ##   #####    ##   ###     ###  ##       ###    ###   # ## ##  #### # ##     ### ##### ##    # #####  ##### #   ##  ##### #   ## ____________________________ SAGA Version: 2.1.4 Further down, the same web page states: <blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' class="gmail_quote" style="margin:0px 0px 0px 0.8ex;border-left-width:1px;border-left-color:rgb(204,204,204);border-left-style:solid;padding-left:1ex">If you have installed SAGA yourself (remember, you need version 2.1), the path to the SAGA executable must be configured. To do it, open the configuration dialog. In the SAGA block you will find a setting named SAGA Folder. Enter the path to the folder where SAGA is installed. Close the configuration dialog and now you are ready to run SAGA algorithms from QGIS. There is no "SAGA block" in the current qgis configuration dialog that I can see.  FWIW, I'm running qgis 2.6.1-Brighton.  There is a "SAGA" providers option under "Processing Options," but no where to specify a "SAGA Folder". However, checking off the "Enable SAGA 2.0.8 compatibility" in appears to unwedge the SAGA functionality.  (I.e., Processing -> Options and configuration -> Providers -> Saga -> "Enable SAGA 2.0.8 compatibility") So apparently that was the actual problem. On Thu, Jun 26, 2014 at 9:00 AM, john polo < [hidden email] > wrote:<blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' class="gmail_quote" style="margin:0px 0px 0px 0.8ex;border-left-width:1px;border-left-color:rgb(204,204,204);border-left-style:solid;padding-left:1ex">
Hi John,
I've had this myself in the past. It's a result of the way it has been installed - are you using Windows or Linux? And what version of QGIS?
Jonathon,
It's on a Windows machine. The QGIS version is 2.2. I used OSGeo4W Advanced Install and installed SAGA via the menus at the same time I installed QGIS.
I started SAGA separately to see if there was something to select or click on, but I couldn't find anything helpful.
Thanks,
John
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
-- [hidden email]
[hidden email]
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/SAGA-toolbox-tp5146391p5178429.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/SAGA-toolbox-tp5146391p5178448.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141218/bce63dee/attachment.html>
