[Qgis-user] poligonal entity copied from a layer to another appears in the table, not in the view
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Dec 19 06:06:03 PST 2014
Sounds weird. Try copying the content of the second file to an empty file to see what happens. If that works, try copying the content of the first file in that new file and see what happens.
Could it be a projection problem? Look to see if both files are in the same projection. I usually use cut and paste between two file with the same CRS.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2014-12-19 04:49, "Alessio Degioannini [via OSGeo.org] " <ml-node+s1560n5178522h43 at n6.nabble.com> a écrit :
I've just copied an entity from a poligonal layer to another.
No geometry or topology error in the source layer, no geo/top errror in
the target layer before pasting the new entity.
After pasting: in the target layer table appears the espected new
record, in the view: nothing. No reply to zoom to selected command.
Check geometry freezes. Check topology ok.
Help me, please.
Thanks in advance.
Alessio
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178555.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141219/46ed8352/attachment.html>
